I would like to use the red one for any reset condition from mach3 and green when program starts, so I guess I'll do the green through relay for green and yellow, and red direct.
I'm currently using severals input for driver faults and spindle fault therefore the best way to see red is through mach3 reset not just the E-Stop
04-02-2016 #2
If you want Red Led to turn on when mach is not reset but not E-stop condition then you'll need to use an Output for this and have the Macro pump watch the Screen Reset Led. Same goes for the Program Cycle. If you ok with not using the yellow Led then you can do this using 2 outputs and No relay required.
Both these should E-stop the machine and when in E-stop Mach should be told and drop out of Reset.
How to connect 2.2KW Inverter VFD?
By Tenson in forum Spindles & Drive MotorsReplies: 20Last Post: 13-07-2020, 01:47 PM -
Connect 121 revamp
By Miller in forum Conect LathesReplies: 2Last Post: 16-10-2014, 05:42 PM -
need CAM that outputs g2g3
By chris in forum CAD & CAM SoftwareReplies: 3Last Post: 28-02-2014, 09:16 PM -
How to connect my driver to my steppers
By speedhound in forum Gantry/Router Machines & BuildingReplies: 9Last Post: 16-01-2011, 02:52 PM
