Thread: V-Groove Bit Recommendation?
Been using a cheap 90 Degree V-Groove with a 22mm cutting edge from ebay. Cost about £ 4. Cut lots of MDF & softwood with it absolutely fine.
04-02-2016 #2
Can you point me to the one you use? Are you sure it doesn't have a flat on the end?
04-02-2016 #3
This is the one I use: V-Groove 90 Degree (think I got mine from a different supplier.)
Cheap and cheerful but I think they're pretty good value for money.Last edited by Rye; 04-02-2016 at 11:09 PM.
05-02-2016 #4
Thank you. It doesn't seem to have a deep enough DOC for 18mm, but I do also cut a lot of 9mm sheet.
The seller of this tool says it comes to a sharp point on the end - http://www.ebay.co.uk/itm/1613257439...xe=exe,ext=ext
05-02-2016 #5
I found a cheap one that was ground to a very good point so I ordered a bunch more.
Those were ground the same way, but missing the centre. Result: Flat bottom.
If you want to do 18 mm ply, you'd need a 36 mm bit. That is BIIIIIG and needs a big and powerfull spindle.
Or you'd be doing minute increments, like 0.1mm per pass as you get deeper.
05-02-2016 #6
Recommendation of Woodwork Shop to Hire?
By Tenson in forum General DiscussionReplies: 6Last Post: 31-08-2015, 02:27 AM -
Recommendation for getting MDF worked on in North London?
By surv1v0r in forum General DiscussionReplies: 0Last Post: 10-09-2014, 12:09 AM -
where do you get the v groove channel extrusions from
By nobby in forum Marketplace DiscussionReplies: 1Last Post: 29-04-2014, 04:19 PM -
Spindle Motor Recommendation.
By cambesol in forum Marketplace DiscussionReplies: 0Last Post: 21-11-2013, 12:15 PM -
Router recommendation for University
By S2L in forum Marketplace DiscussionReplies: 12Last Post: 05-12-2012, 11:58 AM
