    Hey all,
    I'm having difficulty turning the ends of my ball screws down. The material seems pretty hard and it seems to be a lot of hassle to get things to cut and then it turns out pretty sloppy and inaccurate with a terrible finish.
    Am I best going with a toolpost grinder or is there some trick or other turning tool I could try?
    Thank you.
    Easiest way is just to anneal the end of the screw. Heat up the end and wrap a damp cloth round slightly further back to stop most of the heat conducting down the screw.
    If you're careful you'll end up with maybe 10-20mm of the portion you're not machining no longer hard ... but if your ballnut doesn't go that far then it's nothing to worry about.
  3. The Following User Says Thank You to Jonathan For This Useful Post:
    as Jonathan says annealing is not that hard to do. if the screw is not too long, you can put the screw in a bucket of water with the part you want to anneal sticking out of the water. also remember that after annealing you will most likely need to straighten the screw and you will be best to use a collet rather than a chuck.
  5. #4
    For the visual type:
    https://emvioeng.com
  6. #5
    Lives in Plymouth, United Kingdom. Last Activity: 23 Hours Ago Has a total post count of 1,748. Received thanks 299 times, giving thanks to others 11 times.
    So, all you need is a convenient induction heating unit! I was a little surprised at the straightening that was done. Assuming that any distortion would occur in the annealed section or at the boundary between that and the "left hard" section, wouldn't any slight loss of straightness be taken care of in the machining? If you are using the untouched threads to hold the screw (decent collet, etc) then I would have centre-drilled, brought up my tailstock centre, and just turned to dimension, confident that the turned part was going to be concentric with the body of the screw. What have I missed?
    - Brian
  7. #6
    I've been resisting the temptation to buy one of these for a while:
    http://www.ebay.co.uk/itm/1000W-ZVS-...4AAOSwcu5URhOk
    Perhaps I should stop resisting....
  1. Best place for hard stops?
    By mitchejc in forum Gantry/Router Machines & Building
    Last Post: 25-11-2014, 06:39 AM
  2. site setting fairy hard at work again?
    By m_c in forum General Discussion
    Last Post: 21-05-2014, 04:53 PM
  3. RFQ: Why is it so hard...
    By ktc in forum Projects, Jobs & Requests
    Last Post: 11-08-2013, 08:05 PM
  4. How hard is it to make diy PCBs if you’re a Noob ?
    By Fivetide in forum General Electronics
    Last Post: 05-04-2013, 12:10 PM
  5. RFQ: Hard colour anodising
    By Mixster in forum Projects, Jobs & Requests
    Last Post: 11-03-2013, 10:58 PM
