    Backplate attached, not shown but its 160mm wide, 20mm thick aluminium machined tooling plate, same for the front plate.
Name:	z axis backplate.pdf
    Blocks are HiWin HGH20CA narrow, screw is 1605.
    If i use full 400mm front plate i can space blocks much wider which i think is generally a good thing?
Name:	z plate 2.pdf
    If we bring in the plates that are fixed to the rear side which connect the X axis carriages to the gantry rails, it works out very nicely i think - the plates are directly connected to the z axis carriage positions.
Name:	z plate 3.pdf
    Plates are dimensioned as 15mm. bottom two are the gantry lower/upper sides and top one holds the z motor
    Metal arrived today, will be on the mill this weekend i think :)
    Ballscrews - with a stepper drive system and 1610 screws, is it allowable to let the nut hit the BK/BF blocks as a means of hard-stops or do i need to also fit physical stops before they hit?
    The machine will have full limit switches so will not be ploughing into the ends too often hopefully ;)
Name:	z plate 3.pdf
    Dave Think you have been got by Classic Gotcha.?
    How are you going to access the holes for fastening the rear plate to the bottom bearing plate.? The Z bearings fasten from back side so can't fit when rear plate is fastened. You'll need to Lift the bearings so can access the bolts.
    ....Scurries off to grab the drawings............
    Ok, it definitely seems to work for me
ID:	17634Click image for larger version.
    Assembly would be to screw the x axis support plates on at the bottom and middle positions, then there is just enough clearance to pass the screws from the back to the front to mount the Z axis carriages, bottom line is tight but room should be ok.
  1. Replies: 6
    Last Post: 28-12-2015, 06:28 PM
  2. BUILD LOG: 1.7*0.74*0.4m Mill / Router building...
    By Jonathan in forum DIY Router Build Logs
    Last Post: 26-04-2014, 04:36 PM
  3. Best all round mill/router? Vertical mill or gantry router?
  4. My first 700 x 500 x 300 Mill/Router machine
    By Lovre in forum Gantry/Router Machines & Building
    Last Post: 09-02-2013, 09:28 PM
  5. FOR SALE: CNC Router/Mill
    By cimbian in forum Items For Sale
    Last Post: 25-09-2012, 01:10 PM
