13-02-2016 #1
Hello
Thank you for entering in my post
I would like to know which would the most profitable way to cut a 7.5 slot +-0.1 x 35mm deep opened from both sides, on aluminium 6082 T6.
I was watching and reading about Trochoidal milling, but I have never used this method before
https://www.secotools.com/en-GB/Glob...oidal-Milling/
With this method you can use all the cutting edge with a small radial cutting depth
I could use 6mm slot-mill with 3 or 2 flutes with length 6 times Diameter, the maximum spindle speed on the machine is 10.000rev/min
What sort of parameters should I set for this cut?
The surface finish tolerance is 1.6
Spindle speed: 3000 rpm
Feed: 500mm/min
Circular interpolation dimeter 7.3mm
Would you put a finish cut?
May you please suggest the best cutter for this operation and best parameters?
Any suggestion will be very appreciative
Thankyou in advance for your help
14-02-2016 #2
Hmm this is a difficult one.
What CAM package are you using to do the motion? Trochoidal motion is a roughing operation and it leaves jagged edges on the walls or you pocket or slot. It thus needs a finishing pass.
7.3mm will leave you 0.1mm per side to finish and at a depth of 35mm that can be pretty sketchy. Ideally you would do trochoidal in this trench (not slot) with a 5mm endmill, 6 would be very tight. So 5mm endmill sticking out at least 40mm is pretty flexible at the tip. And 3000rpm is a bit limiting.
To do this job I would actually go with conventional milling, slotting back and forth with a 6mm endmill, or even a 1/4" one (6.35mm). Again the stick out length will become critical. For best results on such deep slots, make the sides of the roughed slot slightly tapered and do multiple light finishing passes. So for example you start the slot at 7.3mm wide at the top and gradually go to 6.8mm wide at the bottom. This will give your endmill an easier time in the finishing operations.
In terms of speed, go at full wack and feed will depend on your endmills capability. use the free FSwizard http://zero-divide.net/index.php?page=FSWizard_SA
Regards
Georgehttps://emvioeng.com
14-02-2016 #3
I'd use a 6mm tool and a ramped internal profiling strategy, by keeping the cutting depth small but constant you can cut deep slots and hold the dimensions as well at the bottom as the top and use a very fine finishing cut if required just to clean things up.
+1 on Zero Divide's HSM Advisor
05-03-2016 #4
Thank you very much indeed to both of you
V-SLOT IN EUROPE by Rat Rig Hardware
By ratrig in forum General DiscussionReplies: 2Last Post: 12-08-2014, 01:28 PM -
WANTED: Wanted - a 1/4" (6.35mm) ER11 collet.
By HankMcSpank in forum Items WantedReplies: 4Last Post: 17-09-2013, 07:45 PM -
6mm shaft to 6.35mm hole?
By JuKu in forum Metalwork DiscussionReplies: 3Last Post: 15-12-2012, 02:29 PM -
New T-slot bed!
By jcb121 in forum General DiscussionReplies: 5Last Post: 17-07-2012, 07:36 PM -
is it possible to slot the edge on a cnc?
By wyndham in forum General DiscussionReplies: 2Last Post: 21-06-2011, 12:25 AM
