Thread: To big steppers?
At 10800 mm/minute (is 10.8 m/minute with 10 mm pitch) the 2 Nm had 0,8 nm of torque left, which is enough for my machine.
The cutting force was set at 100N in these calculations.
I cant run higher speeds on a ball screw of the length I am using.
Steppers with higher torque had a torque curve that plummeted as soon as they start rotating, the 2 and 3 nm motors were comparatively flat.
25-09-2016 #2
05-02-2017 #3
I thought I'd post a video of the machine during it's acceleration tests today.
Now I'm unsure of what Jazz means but here is the machine running at 0,4 G with two 2 Nm steppers and 1610 ballscrews:
Topspeed is 10200 m/minLast edited by Sven; 05-02-2017 at 02:21 PM.
05-02-2017 #4
What I said was Don't require 8Nm motors which is still true. Also that 2Nm will struggle while cutting at higher feeds. Cutting air is very different to cutting the hard stuff so suggest you stick cutter in and see how well it handles cutting with decent DOC at 8000mm/min.! (Which is MDF like feeds)
05-02-2017 #5
Ah, I thought it might be in that direction.
I'll test and let you know!
05-02-2017 #6
05-02-2017 #7
Whoops, well spotted!
10200mm/minute.
Drives without steppers
By Wobblycogs in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 27-03-2014, 01:07 PM -
Cheapest CNC steppers I've ever seen!
By D.C. in forum Marketplace DiscussionReplies: 5Last Post: 02-02-2013, 11:22 AM -
Different voltages on different steppers
By Lovre in forum Motor Drivers & ControllersReplies: 2Last Post: 12-12-2012, 11:28 PM -
Has anyone used these steppers or drivers?
By Jonathan in forum Stepper & Servo MotorsReplies: 2Last Post: 24-03-2011, 02:24 PM -
Emco 5PC steppers
By Ian Hart in forum Stepper & Servo MotorsReplies: 17Last Post: 26-02-2010, 02:47 PM
