    Currently reading in about steppers and i wonder, as long as the driver are matched well with the stepper, are there any downsides by "overdoing" it. By chosing a to powerful motor?
    Read somewhere that optimal is best and i get that current flow throw the motor when it stands still creating holding torque. More torque = more current, heat and so on but what so bad about that?
    Provided every thing in the chain matches then no there nothing wrong with having a motor that's more powerful than your needs. . . . However.?
    Larger motors commonly have much Higher inductance which means they require high voltage to get speed from them. Even then they struggle to reach the same speeds smaller size motors can with good drives and voltage. The chain doesn't just stop at the drives.?
    To get the same or equal performance that of little stepper then Large stepper based system will need to consider linear motion ie: screw pitch. So It's a very common mistake for people to go out and buy large motor thinking BIG is better only to be sadly disapointed with the performance because they didn't match the rest of the system.
    Then you have added costs.? . . . The voltage required to get good performance from large nema 34 steppers is much higher than smaller nema 23 steppers require and typicly the drives run at mains voltage. This makes them much more expensive. The motors them selfs are also much more expensive, typicly 2 or 3x the price of nema 23.!!
    Regards Heat then yes most heat is generated when stood still and heat reduces the life of the motor due to Iron losses etc. But most good quality drives will provide feature to deal with this by dropping current to 50-60% while at Zero RPM. This is called current recirculation, you'll often hear steppers hissing or ticking when stood still which is the Recirculation circuit doing it's job.
  3. The Following 3 Users Say Thank You to JAZZCNC For This Useful Post:
    Ok, but that makes things a bit easier.
    Ive allready decided to get 3 of the more decent Leadshine drivers like the 882's or something like that. As i Am thinking they will be one of the parameters limiting what steppers to choose. I will also use the IP-M btw.
    I read a thread (saw your name in it to) where a Guy had compared some motors and calculated there (real) torque at 1000 rpm with parametern like inductance and other things in mind. Offcourse thats a more interesting way to go than just read the torque figurers given on the motor Specs.
    I dont really have any references yet, what is much torque for my gantry?
    Machine size is about 600x900 inside the frame. 2 RM1610 screws at X and 1605 at Y and Z. The x axes will be slaved by belt and a larger motor.
    I want to be able to work with alu as good as possible with this gear. The router is a Makita 700 something...
  5. #4
    Ok well first the Leadshine AM882 are good drives but even those will limit the performance of Large nema 34 motors. I wouldn't go above 8Nm with Nema34 motor using AM882's and would run them no lower than 70vdc. I would also try to find 8 wire motors so can wire Bi-polar parallel. Most nema 34 are 4 wire and wired series which means you'll need more voltage to get speed and torque. Hence why they use drives with Mains voltage.
    Also don't take much notice of Speed/torque curves from most motor data sheets you see unless high end brands because they are meaning less in real world.
    Regards working with Aluminium then Makita router isn't going to last long or be very good. Wood routers are far too fast for most cutters and don't have enough torque. The higher cutting forces also kill the bearings quickly.
  6. #5
    Dont u Think that large 34`s are a bit overkill for my setup?
    Btw the whole Point in the article i was referring to was to calculate the torque based upon inductance, wiring and so on, not to just read the sheets.
    What i am building is a garage/hobby machine, not industrial. I will probably mostly cut MDF for speakerbuildings and so on but i want to be able to cut alu if i want to. There are many examples out there with these kind of routers cutting alu successfully. I guess you just have to do it right with feeds and speeds and all that.
    What i was hoping for was som kind of hint like "you need about that size and torque for your demands".
    Thinking about not being so lazy and do the math and see what i need but it would be great anyway with a hint...
  7. #6
    If you don't have enough metal to dump the heat you will be concerned about the rotor magnets hitting their Curie temperature or the field coils melting their insulation.
    If the motor shaft dumps it's heat in to the screw, the screw will expand. If the shaft does not dump it's heat in to the screw, where is the heat to go?
    You will probably never have a problem, but if your motors run hot you will always worry, especially when considering leaving it unattended for that long job
  8. #7
    Quote Originally Posted by JW1977 View Post
    If you are running 2 screws connected together with belts which you said you was then no it's not at all.
    You like others think that because Mdf is soft it's easy to cut, which it is. But what you don't realise is that while easy to cut it requires feed rates which are fast so you require certain amount of speed from steppers. Now because steppers lose torque when speed rises and you have one motor turning 2 screws along with drag etc from belts then you'll need the extra torque 34's provide.
    I'm not guessing on this I build these size and type of routers all the time and I can tell you without doubt that 3 or 4Nm nema 23 cannot handle 2 screws connected with belts on well built machine and give you feed rates enough to cut MDF properly and reliably without chance of lossing steps under load.
    Cutting Ali is easy enough provided the machine is strong enough. It's achieving the correct speeds for woods, mdf which catches people out. If you don't have strong enough motors then you'll have to lower feeds so don't stall or miss steps. If you do this too much and can't reach correct feed rates required for cutting then tool wear and finish suffer.
    Really has nothing to do with Hobby or industrial usage. It's just case of selecting the correct motors and components so they work together and give balanced machine that will give feed rates required for range of materials you intend to cut.
    If you want a hint to which motors then here's one.?. . . . Square ones.!! . . . . . Seriously how can we give you a clue without you give us clue to how machine is built.!. . . Is it built from Tissue or Cast iron.? Does it's use Skate bearings or levitation for linear motion.? So many factors come into play that without a clue it would be wrong to recommend sizes etc.
  9. #8
    My router has an inside area of 970 by 500 and I use an 8Nm Nema 34 driving twin 1610 ballscrews via a belt (I'm using a 230V driver not an AM882 to get the speed) in my X, Nema 23s on Y and Z with Y having a 1610 and Z having a 1605 ballscrew driven by AM882 drivers...it munches MDF and I have it at 7500 m/min plus for cutting plastic such as Acetal....I also use the IP-M and its a great piece of kit.
    Your belt will be more like 2m to 2.5m long with a cutting area you're looking for.
    Neil...
    Build log...here
  10. The Following User Says Thank You to njhussey For This Useful Post:
  11. #9
    Thanks! I went through your build log, nice work!
    I’m also into RC and are really looking forward to get the machine ready.
    After all the input from you and others here I will probably go for the IP-M and I will slave the X by belt.
    About the belt and pulleys . Can you recommend any products? If I remember correctly the distance between the centers of my ball screws is 684 mm at X.
    I was figuring twice that + a little for the pulleys and some kind of tension adjustment device at center.
  12. #10
    It will depend on how you setup the tensioning system and idlers. But with 20 teeth pulleys which is good size because gives nice balance of teeth engaged and pulley size which affects inertia of the screw and can have big affect on power requirements. Arranged something like whats in the picture then your belt length will be in the region of 1600mm.
  1. Drives without steppers
    By Wobblycogs in forum Gantry/Router Machines & Building
    Last Post: 27-03-2014, 01:07 PM
  2. Cheapest CNC steppers I've ever seen!
    By D.C. in forum Marketplace Discussion
    Last Post: 02-02-2013, 11:22 AM
  3. Different voltages on different steppers
    By Lovre in forum Motor Drivers & Controllers
    Last Post: 12-12-2012, 11:28 PM
  4. Has anyone used these steppers or drivers?
    By Jonathan in forum Stepper & Servo Motors
    Last Post: 24-03-2011, 02:24 PM
  5. Emco 5PC steppers
    By Ian Hart in forum Stepper & Servo Motors
    Last Post: 26-02-2010, 02:47 PM
