Quote Originally Posted by reefy86 View Post
just to throw something in there would this make sense for you guys or does it look confusing :)
Name:	left gantry plate dimensions.jpg
I think you have too many measurements some are duplicated also the bottom 4 holes are drawn differently ie not showing the countersunk bit. I don't see the line down the centre holes sizes. If all the holes are the same size you can say that. Unless the holes tapped just say the hole size ie not M8 8.1 as a M8 hole would be 6.8mm to be tapped.
If hole are through holes I would say that instead of 30mm.
I would reference all the measurements from one end and one side. Do you really need 30mm plate?
Do you have a dxf file for this. If not I can do one for you.
