    thank you that makes alot of sence to do it that way tbh and feels natural.
    cheers
    Ash
    just to throw something in there would this make sense for you guys or does it look confusing :)
Name:	left gantry plate dimensions.jpg
    Quote Originally Posted by reefy86 View Post
    I think you have too many measurements some are duplicated also the bottom 4 holes are drawn differently ie not showing the countersunk bit. I don't see the line down the centre holes sizes. If all the holes are the same size you can say that. Unless the holes tapped just say the hole size ie not M8 8.1 as a M8 hole would be 6.8mm to be tapped.
    If hole are through holes I would say that instead of 30mm.
    I would reference all the measurements from one end and one side. Do you really need 30mm plate?
    Do you have a dxf file for this. If not I can do one for you.
    Just to add to what Clive says, I don't see any measurement for the actual position of the 4 and 8 grouped holes on the plate, try and pick two sides(Datums) to take the measurements from and maybe positional tolerances if its important to you. Also you don't need the length of the angled side, an angle would do.
    Cheers, Charlie
    ahh yeah sorry i forgot about the position of the holes, as for the bottom 4 the reason why they are different is because the counterbore are on the opposite side. i do not have a dxf file as im new when it comes to drawing so that was actually my first drawing to show you guys lol.
    cheers
    Ash
    forgot to mention i want a close fit on the through holes so instead of 8.4mm i wanted 8.1mm thats what i meant to of said.
    Ash
    Ash
    If you want alignment, use dowel pins or shoulder screws not plain screws. tightening the through holes will cause tolerance stackup issues.
    https://emvioeng.com
    cheers
    Ash
    Well then you have not said on the drawing which side is being countersunk. You have not mentioned 8.4mm only 8.1mm. If you say you want a hole for M8 it will probably end up at 6.8MM
    So
    1: Do you need 30mm ali
    2: You don't need to say M8 just the hole size you want and whether it is through hole or to a depth
    3: set all your measurements from two datum's ie bottom and one side.
    thanks guys, 30mm probably is ott what would you recommend for all round? i think i will stay with 30mm on the front z axis plate though but for everything else would 25 do? i know 20 is the minimum.
    and with the holes so i just say 8.4mm through on plate 1 and 6.8mm tapped 15mm depth on plate 2?
    Ash
  1. CNC machine cutting incorrect dimensions
    By Clem in forum Machine Discussion
    Last Post: 26-02-2014, 10:00 PM
  2. denford orac tail stock dimensions
    By dazza in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 24-11-2013, 10:42 PM
  3. Cross sectional dimensions for CAD drawings
    By Husky in forum Gantry/Router Machines & Building
    Last Post: 24-02-2013, 06:19 PM
  4. BK12 Hole Spacing Dimensions On Top
    By Hobgoblin in forum Lead Screws, Nuts & Supports
    Last Post: 21-09-2012, 10:31 PM
  5. Dimensions and Weight of Denford Starmill PC Please
    By cristec in forum Milling Machines, Builds & Conversions
    Last Post: 13-08-2012, 07:02 AM
