    Hi guys,
    I just had someone recommend this forum at Cnc Zone.
    badically I am looking for someone to help or build a
    cnc Hotwire machine to cut polystyrene blocks.
    i have machines in place that can copy from (improve).
    also would need a machine that can cut cubes or pads
    (slicer/dicer).
    Thanks in advance !
    I'm massively busy but if you don't get any offers to help or build then drop me PM with your email and I'll have a look at it for you you.
    When you say would need slicer dicer machine. Are you thinking 2 different machines or saying you want this machine to do both jobs.?
    If one machne for both are you thinking two wires horizontal and vertical on separate moving axis or one wire with turn table.?
    Hi I'm thinking of having 2 machines. The slicer machine would be able to cut up and down and then a separate head for left and right. I can grab a picture to get the rough idea of both.
    Quote Originally Posted by Nitrusoxide View Post
    Yes think I know what you mean but pics always help. Why two machines.? Twin axis machine could do both jobs or would they be running side by side at same time.?
    thats interesting, I have always worked with separate machines but if one can be produced all the better.
    Hopefully this works, one of the slicer dicer and profiler (cnc) machine. These are 20 years plus designs fhoug
ID:	17645   Click image for larger version.
  1. RFQ: Polystyrene cutting machine , Cnc Hotwire / slicer dicer.
    By Nitrusoxide in forum Projects, Jobs & Requests
    Last Post: 19-02-2016, 12:15 PM
  2. BUILD LOG: CNC Hotwire 4 axis foam cutter
    By Skipsoaring in forum Hotwire Cutting Machines
    Last Post: 29-07-2015, 04:26 PM
  3. Looking to offer services to other diy machine builders
    By matttargett4 in forum Gantry/Router Machines & Building
    Last Post: 03-01-2013, 01:02 PM
  4. NEW MEMBER: Amateur machine builders from Russia-Kazakhstan.
    By Baha in forum New Member Introductions
    Last Post: 23-10-2010, 03:47 AM
  5. Mini CNC lathe builders
    By GeorgeD in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 28-07-2010, 10:00 AM
