Page 11 of 11 FirstFirst ... 91011
  1. #101
    Yep, thats pretty much what i thought while i watched my new cutter get buried in the bed :)
    I have a little less trust for it now but thats probably not a bad thing.
  2. #102
    Lives in Marple Stockport, United Kingdom. Last Activity: 17 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,342. Received thanks 618 times, giving thanks to others 82 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    OK I have mine sorted I use a Purelogic board for the router but I have a simple bob tagged off it for the probe this had 5V inputs pulled high. I had put a resistor in series with the input pin sometime ago and I had forgot about it. I measured the voltage on the probe plate, It was only about 3.3V so there was my problem it was just on the edge of working when I removed the resistor it measured 5V. Problem solved for me anyway.
  1. BUILD LOG: First time build - Steel Frame CNC Router
    By examorph in forum DIY Router Build Logs
    Last Post: 19-10-2023, 06:25 PM
  2. BUILD LOG: Well here goes... Aluminium frame router design
    By CharlieRam in forum DIY Router Build Logs
    Last Post: 11-05-2020, 12:39 PM
  3. BUILD LOG: Steel frame cnc router design/build
  4. WANTED: CNC Mill/Router for Cutting Aluminium
    By kylelnsn in forum Items Wanted
    Last Post: 09-08-2012, 09:54 PM
  5. BUILD LOG: Aluminium Extrusion CNC Router Build
    By joshendy in forum DIY Router Build Logs
    Last Post: 10-04-2012, 08:26 PM
