    .......this thing is being built like a mini battleship!
    I know that one, my Z front plate is 40mm thick...think I only took a similar amount out of that, overkill??!!
    Neil...
    Build log...here
    Better over than under ;)
    Day off today so hit the project...
    X / Z axis finshed...
    Rear face of the tool mount plate with the linear rails...
    Front of the Z axis with some linear rail carriages in place...
    Back of the Z axis with the X axis carriages in place...
    Rear frame support plate fitted to the main beams...
    Next up is the front frame plate and mount for the Y axis motor. :)
    Bit more today...
    The bare frame - extremely rigid, surprised me!
    Inside of the front plate (maybe the back, not sure yet) idler bearings to shift the belt path...
    The Y axis screws temporarily fitted...
    The gantry being built up...
    The Z axis in place...
    Z axis lifter screw and motor fitted...
    So far, my CAD efforts have been 100% perfect, every single part drawn has fitted just where it should be Torsionally, the gantry is very stiff - pushing on one side brings an immediate response from the other which is good, the Z axis looks like it will be just as tight.
    Now i need to fabricate an idea for a method of joining the Y axis nuts to the gantry cross-beam.
    Tuff littel Bird ain't she.. .
    Certainly is Jazz, this thing is probably more rigid then 'Mr Flexy' the Bridgeport ;)
    Small progress today, mostly tidying up loose ends and fitting parts...
  1. BUILD LOG: First time build - Steel Frame CNC Router
    By examorph in forum DIY Router Build Logs
    Last Post: 19-10-2023, 06:25 PM
  2. BUILD LOG: Well here goes... Aluminium frame router design
    By CharlieRam in forum DIY Router Build Logs
    Last Post: 11-05-2020, 12:39 PM
  3. BUILD LOG: Steel frame cnc router design/build
  4. WANTED: CNC Mill/Router for Cutting Aluminium
    By kylelnsn in forum Items Wanted
    Last Post: 09-08-2012, 09:54 PM
  5. BUILD LOG: Aluminium Extrusion CNC Router Build
    By joshendy in forum DIY Router Build Logs
    Last Post: 10-04-2012, 08:26 PM
