06-03-2016 #2
Ok I presumed friendship ;)
Certainly tough-nut though ;)
06-03-2016 #3
06-03-2016 #4
07-03-2016 #5
One almost oversight i spotted tonight - the holes on the ballscrew nut flanges, i presume these are for grease nipples?
To get to my Z axis ones will mean taking the bed off - no big deal there but the z axis one is buried.
The question - how often do screws need greasing?
09-03-2016 #6
Got the Y axis screws synchronised and belt fitted tonight, fine-tuned the ballscrew nut brackets and the bottom end is just about done, threw the bed and over-bed on for a photo...
The 15mm alu over-bed will drilled/tapped for mounting studs etc, it's a little shorter than i would like and cost me about 50mm of Y travel but it will do ok for a while.
Just waiting for some alu bar to arrive for the X axis motor mount and we will be wiring up for motion testing :)
09-03-2016 #7
I think for the size, it will perform very well!
BUILD LOG: Well here goes... Aluminium frame router design
By CharlieRam in forum DIY Router Build LogsReplies: 186Last Post: 11-05-2020, 12:39 PM -
WANTED: CNC Mill/Router for Cutting Aluminium
By kylelnsn in forum Items WantedReplies: 5Last Post: 09-08-2012, 09:54 PM -
BUILD LOG: Aluminium Extrusion CNC Router Build
By joshendy in forum DIY Router Build LogsReplies: 9Last Post: 10-04-2012, 08:26 PM
