13-03-2016 #25
Dave these switches 100% do work for both I use them all the time. It's either your using them wrong or possible the BOB doesn't work like you think.?
How you have worked around the problem may well work but I wouldn't trust for repeatabilty.
I think the answer to the problem is you'll need to use 10k resistor to force the input high.Last edited by JAZZCNC; 13-03-2016 at 12:12 PM.
BUILD LOG: Well here goes... Aluminium frame router design
By CharlieRam in forum DIY Router Build LogsReplies: 186Last Post: 11-05-2020, 12:39 PM -
WANTED: CNC Mill/Router for Cutting Aluminium
By kylelnsn in forum Items WantedReplies: 5Last Post: 09-08-2012, 09:54 PM -
BUILD LOG: Aluminium Extrusion CNC Router Build
By joshendy in forum DIY Router Build LogsReplies: 9Last Post: 10-04-2012, 08:26 PM
