    Even the super cheap Ebay ones work ok dave.
    You haven't wired the switch powers in series have you.? That flickering looks like struggling for volts.!
    Hi
    No, all wired in parallel as described in manual, I have a quality bench psu and will test them on that now...
    If you fully cover the end with the target the LED is solid on, but mach picks up the very first flicker and takes that as the position, as expected.
    Maybe these are fakes or junk clones which have the output conditioning circuit missing??
    Nah I'd be suspecting the conflict between swithc and BOB my self. The input isn't conditioned correctly. Stick a 10K resistor on between 12v and pin 10.
    Worst case is it will slow down the input reaction time.
    I've had this before with prox switches and PMDX board using ESS.
    Thanks Jazz, I have some updates..
    This seems to be a PSU issue believe it or not!
    The BOB is powered from a little 15v SMPS, the sensors are powered from the BOB which has a DC-DC converter and puts out 12v.
    First test was to put a sensor on my variable bench PSU, they worked perfectly! Clean on and off LED - perfect.
    So i tried running the sensors direct from the 15v PSU - these are NPN so supply voltage does not affect the output signal and the 0v in/out is common on the BOB - result was that it worked ok UNTIL I took Mach out of reset when the flickering returned - baffled!
    Next i tried running the BOB from the bench PSU - perfect result and i could even enable the limits (on one axis anyway) and it all worked as I first expected it should.
    So - do we have a duff PSU, are these sensors sensitive to SMPS output?
    I am not sure what to try now - baffled.
    Maybe add some uF to the output of the supply and maybe some filtering?
    I might get the 'scope out and see whats on the supply.
    Get a different PSU? (this one came from CNC4YOU as did the BOB)
    Here's another oddity - the plasma always wipes out the radio as soon as the drives are enabled, now it seems this build does the same - as soon as the drives kick in, the radio gets washed out.
    Both builds use SMPS and all parts came from CNC4YOU. Food for thought.
    Hence why I won't use SMPS(switch mode power supply for those wondering.!) on any drives. The fact you have probelms with one on the BOB doesn't inspire confidense in the BOB for me. It's needs should be simple and only be pulling milli amps so not taxng to any psu.!
    I need to narrow things down a little - is it the drive PSU upsetting the BOB or is it the BOB PSU ?
    The BOB pulls 150mA including the three sensors.
    Will be back soon with some results, the BIG worrying me is the radio interference - the plasma is fully grounded etc and works perfectly BUT it pumps out RF like billy!
    Maybe I need to ditch the SMPS's and go linear.
    Off for some tests.....
    Hi Dave,
    Going back to your first motion videos it looks like the X bearings could come off the ends of the rail as there is no hard end stop. Does something on the ballscrew contact first to prevent this?
    To answer this question then NO they usually work fine with SMPS. That's what I use for 24v circuit. Try a different PSU
  1. BUILD LOG: First time build - Steel Frame CNC Router
    By examorph in forum DIY Router Build Logs
    Last Post: 19-10-2023, 06:25 PM
  2. BUILD LOG: Well here goes... Aluminium frame router design
    By CharlieRam in forum DIY Router Build Logs
    Last Post: 11-05-2020, 12:39 PM
  3. BUILD LOG: Steel frame cnc router design/build
  4. WANTED: CNC Mill/Router for Cutting Aluminium
    By kylelnsn in forum Items Wanted
    Last Post: 09-08-2012, 09:54 PM
  5. BUILD LOG: Aluminium Extrusion CNC Router Build
    By joshendy in forum DIY Router Build Logs
    Last Post: 10-04-2012, 08:26 PM
