13-03-2016 #26
Well, I am just about ready to give up for the day! And I hate shutting up shop on a negative position. :(
It works fine if i run off the variable bench PSU but not on the little SMPS, but i don't think it's needed to spend £110 on a PSU just for the BOB!
Here's a video showing the result on the SMPS...
https://youtu.be/m9_6XrzW0Fc
And here's one showing what I expected and indeed what I get on the bench PSU...
https://youtu.be/XcI2J5RcyrE
Now the big question is WHAT DO I DO??
Obviously I will be throwing this at CNC4YOU as it's all their components but they usually blame the setup or the earthing or the wiring blah, blah, blah...
Facts...
The drive PSU & drives wipe out FM radio when engaged.
The BOB PSU does not work with my sensors.
The sensors appear fine when on a different PSU.
I am a bit p1ssed off at present as this little setup should have been easy ;)
Just about ready to pour a big one.
BUILD LOG: Well here goes... Aluminium frame router design
By CharlieRam in forum DIY Router Build LogsReplies: 186Last Post: 11-05-2020, 12:39 PM -
WANTED: CNC Mill/Router for Cutting Aluminium
By kylelnsn in forum Items WantedReplies: 5Last Post: 09-08-2012, 09:54 PM -
BUILD LOG: Aluminium Extrusion CNC Router Build
By joshendy in forum DIY Router Build LogsReplies: 9Last Post: 10-04-2012, 08:26 PM
