19-03-2016 #25
Well, she survived the rewire and panel fitting, also got the VFD fitted and spindle running under 0-10v and stop/start from the BOB. Surprised how quiet the motor is.
Installed the new screen-set (2010) and got that going, looks nice. Tweaked the homing speed and at 15% the homing accuracy is now +0 to -0.02mm which is far better and will leave it there for now.
Questions ---
Touch plate -
to make this work i need to connect the probe input to ground via my tool, I presume it is OK to connect the BOB 0v line to machine chassis in order to make this work with only one probe wire??
Spinde Stop -
Do we use coast-to-stop or ramp-to-stop??
Spindle acceleration -
What sort of spin-up setting is good in the VFD?
I presume this also goes in Mach3 Spindle delays?
Got to finish my bed plate now...
BUILD LOG: Well here goes... Aluminium frame router design
By CharlieRam in forum DIY Router Build LogsReplies: 186Last Post: 11-05-2020, 12:39 PM -
WANTED: CNC Mill/Router for Cutting Aluminium
By kylelnsn in forum Items WantedReplies: 5Last Post: 09-08-2012, 09:54 PM -
BUILD LOG: Aluminium Extrusion CNC Router Build
By joshendy in forum DIY Router Build LogsReplies: 9Last Post: 10-04-2012, 08:26 PM
