They are quite small for a 3d printer so probably best suited to laser engraving which with 2w diode costing around £60-70 on aliexpress would cut card, paper, cloth, thin leather and rubber etc and engrave but not on clear plastics etc.
27-02-2016 #2
Hi Lucan07
I like the idea of a laser. I have no experience of these machines so please bear with me. :-0
If I wanted to cut 3mm birch ply I believe I would need something like a 30W+ laser. (Feel free to correct me. )
Would the machine need bigger motors, drivers etc? .. and if so why? (To improve my understanding and not to challenge you) Or would I get away with it?
When shopping for a laser is there anything I need to be aware of?
Getting excited at the thought of a new machine! I even know where it will go! :-)
Thanks so much for your valuable help.
27-02-2016 #3
Yes a 30w Co2 laser would be about right for 3mm ply, you could get away driving with that set up if bearings etc smooth.
Shopping for lasers probably means a cheap chinese laser and power supply etc, costwise building it yourself would be more expensive than buying a k40 40w c02 3020 system from ebay slightly over £320.
Buying tubes generally means the chinese on Aliexpress want courier to prove arrived broken before claim accepted, couriers are not going to wait for you to open PLY box then cardboard and remove packaging so its a gamble on it actually arriving in one piece. Cheap chinese lasers vary in quality and do not last last very long if run at anything over 60% power.
I had a friend who purchased the cheap ebay K40 model and the tube lasted only 2 hours, but with a claim and persistence quoting UK trading full refund obtained for him and they were responsible for collection of the faulty item within 7 days which they failed to do and have still made no attempt to do so, now his property. Only buying through Ebay and paying with paypal saved him getting ripped off claiming via credit card companies etc possible but a real pain with eBay was simple peobably many such claims they were on the ball anyway.
If you needed larger area than 3020 I would still go that route, play with it on arrival and make sure all ok with unit and then use parts or modify to get what you needed from your build, ensure cooling up to scratch running hot radically shiortens life of tubes but a 2ltr bottle of water frozen dropped in a bucket would keep you going for a few hours.
27-02-2016 #4
Cheers Lucan07
I'll take your advice on that. Which is great as I now need to buy the machine you mentioned above and build my New machine. Result! :-)
Excellent food for thought.
Much appreciated.
Power supply help
By Davo242 in forum General ElectronicsReplies: 18Last Post: 07-01-2016, 01:00 AM -
FOR SALE: power supply
By Web Goblin in forum Items For SaleReplies: 0Last Post: 14-09-2014, 03:19 PM -
Minimal-cost Power Supply Strategy - Repurpose Laptop Power Supplies
By LoveLearn in forum General ElectronicsReplies: 0Last Post: 25-01-2012, 09:29 PM -
FOR SALE: 50V 20A Power supply
By Jimmybristol in forum Items For SaleReplies: 8Last Post: 30-05-2011, 11:01 PM -
power supply
By hitmythumb in forum General ElectronicsReplies: 6Last Post: 21-06-2009, 10:27 AM
