Terry,
wise choice in ditching the parallel port and going with a motion controller. The tb6560 however will still be required should you go with any motion controller as it is a breakout board and a set of stepper motor drivers all in one.
Our, (guys correct me if I am wrong but I am pretty sure) general opinion is that Mach4 is not quite there yet. Mach3 has more going for it in the sense that there are more plugins, screens, wizards and the like and many more users able to give you help.
Warp9TD have a little program that will make the transition to using the smoothstepper easier on their website however I still prefer to do it manually. It is not that difficult.
https://emvioeng.com
21-02-2016 #2
You'd be better ditching the TB6560 first and moving to a decent BOB with separate driver for each axis.
I have a very stable CNC mill on a PP, I am looking at the future and it's not PP but at the present it works perfectly,
Regards,
Nick
21-02-2016 #3
Whats a BOB. So let me get this right.the pc connects to the smoothstepper and then I need a second board to work the motors. I don't really wish to buy some cheap useless chinese card or an high end usa card (import taxes to high) so what is a good middle of the road card that will work alongside the mf70 and the smooth stepper. Michael
21-02-2016 #4
The Break Out Board takes the signals to and from the parallel port interface, usually buffering them to avoid frying your PC and has outputs for motor drivers, spindle control, coolant control etc.
Buying BOB & drivers in one lump cheap simply ensures that when one component becomes problematic the whole board is junk - way to save money! ;-)
- Nick
21-02-2016 #5
Ok.i would like to keep the motors I have, as they work ok. So what would be a good board to get that fits between the smoothstepper and the motors. Michael
21-02-2016 #6
you can still use the TB6560 to get you going. It has its faults but is cheap.
In the future should you wish to upgrade to individual drives for each axis, then you can look at some of the generic breakout boards. google "5 axis usb breakout board". The USB is a misnomer, it only takes 5V from the USB to power some electronics.https://emvioeng.com
21-02-2016 #7
I would like to dump the tb6560 as it would be the weak link in the chain.there are so many cheap rubbish imports on the uk market.what is a good easy to use uk available card . Michael
21-02-2016 #8
Terry I wouldn't buy Smooth stepper or anything yet because chances are your problems are not with the parallel port but the TB6560 or some thing else.
What is the problem exactly.?
Excuse if you know this but let me explain how typical setup goes.
PP --> BOB --> Drive --> Motor
Parallel port(PP) sends/recieves signals to Breakout Board (BOB) which then Sends pulses to individual Drive for each motor, It also recieces signals from outside sources like E-stop or limits etc.
All the Smooth stepper does is remove the parallel port from the equation. It's great piece of kit and recommended thing to buy but not yet because like as been said you probably don't need it.
For less than price of ESS you'll buy 3 new Digital drives, Cheap BOB and PSU that will blow the Tb6560 out the water and turn your mill into all new animal even with the PP.!!
Smoothstepper
By Sparks in forum Warp9 (SmoothStepper)Replies: 6Last Post: 05-11-2018, 10:03 AM -
Help mach3 ethernet set up
By kell in forum Artsoft Mach (3 & 4)Replies: 3Last Post: 06-12-2015, 10:26 PM -
Any SmoothStepper UK Resellers?
By Mad Professor in forum Motor Drivers & ControllersReplies: 15Last Post: 12-08-2014, 08:19 AM -
CSMIO/IP-M vs Ethernet SmoothStepper (Begone foul parallel port!)
By Greeny in forum Control Hardware & SystemsReplies: 20Last Post: 14-11-2013, 11:59 PM -
To SmoothStepper or not to - that is the question
By bruce_miranda in forum General ElectronicsReplies: 4Last Post: 29-09-2008, 06:31 PM
