If you want to remove the parallel port and TB then you won't do this for less than £200. The ESS alone is nearly that much. By now you may realise all the ESS does is replace the parallel port. This is why I said keep the PP and buy better quality drives.
Honestly New Digital drives run thru a BOB and with a little more Voltage will transform your machine. Then at later date buy the ESS if you like. £200 will get you 3 Leadshine DM556 Digital drives new 42V PSU and BOB.
Smoothstepper
By Sparks in forum Warp9 (SmoothStepper)Replies: 6Last Post: 05-11-2018, 10:03 AM -
Help mach3 ethernet set up
By kell in forum Artsoft Mach (3 & 4)Replies: 3Last Post: 06-12-2015, 10:26 PM -
Any SmoothStepper UK Resellers?
By Mad Professor in forum Motor Drivers & ControllersReplies: 15Last Post: 12-08-2014, 08:19 AM -
CSMIO/IP-M vs Ethernet SmoothStepper (Begone foul parallel port!)
By Greeny in forum Control Hardware & SystemsReplies: 20Last Post: 14-11-2013, 11:59 PM -
To SmoothStepper or not to - that is the question
By bruce_miranda in forum General ElectronicsReplies: 4Last Post: 29-09-2008, 06:31 PM
