Thread: Limits, homes, override switch
25-02-2016 #19
Get it :) Sounds obvious now :)
I looked up on AliExpress but not sure I get original ones... where do you get them from ? Also, If I understand well the wiring you explain and look at the documentation as well, it seems that you're connecting them as PNP type sensor and that blue connects to both 24V PSU GND pin and BOB's input terminal's GND pin ? Is it not an issue that they share they share the same GND though they are circuits operating at different voltages ? I guess GND is GND, doesn't matter the voltage ? I like to fully understand things, that's why I ask ;)
That's a very important thing you note here, and I will modify my circuit to take drives alarms into account, in fact, last week I made a mistake in Mach3 and while running un-regenerated toolpath and bad configuration, motors stalled, so I almost broke my X axis, because the alarm went off, but obviously was not connected to anything, so X2 kept running... To avoid that in the future I'll wire the alarm outputs as you explained, thought the limits don't belogn to the e-stop circuit. Thanks for the advice :)
feedrate override using rotary momentary switch?
By routercnc in forum General ElectronicsReplies: 8Last Post: 26-02-2015, 10:11 PM -
Proximity switch NPN or PNP
By Matt81 in forum General ElectronicsReplies: 9Last Post: 19-04-2014, 11:38 AM -
stepper acceleration rate - limits?
By dsc in forum Stepper & Servo MotorsReplies: 11Last Post: 02-03-2014, 02:25 PM -
limits on mill table
By John11668 in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 31-08-2011, 06:46 PM -
Limits or homing switchs???
By Ross77 in forum Computer SoftwareReplies: 11Last Post: 28-03-2010, 03:17 AM
