Thread: Limits, homes, override switch
22-02-2016 #5
First - What switches are you using for homes and limits ?
The 3 wire Inductive type of switch usually floats (no connection) or grounds the switch contact depending on whether NC (normally closed) or NO (normally open), The fact that you use 24v or 10v to power the inductive sensor doesn't matter.
NC are normally wired in series with the first switch being connected to actual GND and the next switch getting its GND from the preceding switch NC contact, with the last switch in the series having the NC contact going to the BoB. This means that if any one switch is triggered then the input to the BoB goes to 'float' and circuitry inside the BoB lifts it to logic 1 (active high).
NO are wired in parallel, so that if any one switch is triggered, the input to the BoB is forced to GND (logic 0, active low).
As Jazz says relays are unnecessary and cause errors in Homing precision.
NC switches are preferred as they fail to 'safe' if you have a circuit break.
Cheers,
Rob
feedrate override using rotary momentary switch?
By routercnc in forum General ElectronicsReplies: 8Last Post: 26-02-2015, 10:11 PM -
Proximity switch NPN or PNP
By Matt81 in forum General ElectronicsReplies: 9Last Post: 19-04-2014, 11:38 AM -
stepper acceleration rate - limits?
By dsc in forum Stepper & Servo MotorsReplies: 11Last Post: 02-03-2014, 02:25 PM -
limits on mill table
By John11668 in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 31-08-2011, 06:46 PM -
Limits or homing switchs???
By Ross77 in forum Computer SoftwareReplies: 11Last Post: 28-03-2010, 03:17 AM
