  1. #5
    Here is picture of a mill, it's a Bridgeport - the most common mill ever made i think, I have one just like it. It's 1100kg of solid cast iron and has a proper 2Hp motor on it.
    It is capable of milling steel, but will only take relatively light cuts due in most part to it's versatile nature - the head can swivel, rotate and tilt, these are great features but make it weaker when it comes to real milling.
    Steel needs lower speeds and more power, yes it can be done with high speeds but you can expect short cutter life and you will only be scratching away the metal.
    That being said, I am building a gantry style CNC machine and fully hope to be able to do fine milling in aluminium but nothing tougher, i am looking at cutters of around 2 - 5mm diameter.
    I really would look closely at what you need to achieve but steel milling is going to be a tough nut to crack.
    Conversions can be done, plenty of Bridgeports have been CNC'd - ball screws are a must and a good machine as a foundation is a big help as lot of them have had a hard life.
  2. The Following User Says Thank You to Davek0974 For This Useful Post:
  1. BUILD LOG: Steel Gantry Machine 1500x750x200
    By toomast in forum DIY Router Build Logs
    Last Post: 02-03-2018, 06:27 PM
  2. WTD: CNC Milling Machine for Alu & Steel
    By Joshi in forum Classified Ads, Buy, Sell & Swap
    Last Post: 09-02-2016, 10:06 PM
  3. polishing stainless steel machine
    Last Post: 17-08-2014, 04:46 PM
  4. A Sturdy Steel Framed Machine Design
    By Boyan Silyavski in forum Machine Frames & Beds
    Last Post: 06-11-2013, 05:58 PM
  5. Cutting 1.6mm mild steel with a CNC machine?
    Last Post: 01-05-2012, 09:56 PM
