Well first have you priced profiled linear rails from china yet.? You may get surprise.!
5mm or 10mm pitch makes no difference to price they cost the same. There would be more down side to using 5mm than 10mm.?
Smaller pitch would give you higher resolution but this comes at the cost of speed and to some degree torque. Higher pitch will give you half the resolution but twice the speed.
Now the main difference lies in torque or more importantly more torque where it's needed which is while cutting. The higher pitch means for the same speed the 10mm will allow motors to spin at half the speed of 5mm. Now because steppers lose torque as rpm increases the available torque from motor is higher because spinning half the rpm but the cutting speed is the same. The main loss is in resolution but even with 10mm pitch you'll still have more than enough resolution for 99.99% of work you'll do.
5mm pitch does provide more mechanical torque than 10mm but still it's motor rpm where it's needed most and 5mm will mean the motors while cutting are spinning near there speed curve threshold where torque drops away fast which isn't good. 10mm will surve you much better and give more flexibilty.
Regards Digital drives then yes they work just the same. If you want to see how shitty analog drives can cripple machines and people not even realise it and also the difference digital drives make then I recently posted a video showing it. Can't remember the post but do search and I'm sure you'll find it.Last edited by JAZZCNC; 27-02-2016 at 01:50 AM.
03-03-2016 #2
Update,
After some research the 10mm ballscrews look like a wise choice (thanks Jazz), Linear rails are still looking like they are out of budget. With my current spec i am floating around the £950 mark which is very near the top end of my budget.
If i can maintain (or reduce this slightly) i would be happy. I am considering a steel box section frame which should reduce the cost (but most likely be less accurate because of my questionable welding skills).
Turning my attention back to the electrical elements and taking you feedback into account jazz i'm looking at the following main elements.
Stepper:http://www.zappautomation.co.uk/elec...per-motor.html2A (Series) 4A (Parallel) /
8 Wire / 1.8Nm Holding Torque / Double shaft
Driver:
http://www.ebay.co.uk/itm/Leadshine-...sAAOSwgQ9VkquTleadsine DM542
1~4.2A 20~50VDC
Power supply
http://www.aliexpress.com/item/600W-...8-830534792d55
It would be good to get some feedback on this combination. My understanding is the DM542 is a lesser version of the DM556 you suggested Jazz. Do i need the additional "buffer" of the DM556?
Also the power supply is rated to 12.5A is this suitable for running the steppers at peak with enough of a buffer.
I am still working on the hardware design and will post up some images soon.
thanks,
03-03-2016 #3
For 60p more I'd go with theses motors. That bit stronger and match perfectly with 10mm pitch screws, I've fitted 100's.
http://www.zappautomation.co.uk/elec...tor-48577.html
Regards drives they are still good drives so yes they will be ok.
PSU wouldn't be my first choice but will work. First choice would be to build toroidal supply which is much better suited to CNC and more relaible. Wouldn't cost much more money.
03-03-2016 #4
Few pence cheaper but same...
https://www.cnc4you.co.uk/Stepper-Mo...YGH301B-Nema23
29-07-2016 #5
I know is old post, but worth to show better prices.
Cheaper and stronger motors uk supplier £96 for 3:
http://www.ebay.co.uk/itm/Nema-23-St...sAAOSw-vlVjjIh
Drivers £93.77 for 3 - 5.6A peak 4A RMS
http://www.ebay.co.uk/itm/3308806091...%3AMEBIDX%3AIT
Power supply £19.88 48V 8.3A
http://www.ebay.co.uk/itm/AC-DC-5-12...r=620616619105
few quid saving + quick delivery.
Got all of them and they ok, PSU seems underpower but for for 3A motors is ok.Last edited by Tom J; 29-07-2016 at 06:56 PM.
FOR SALE: fixed gantry router/mill up for grabs
By dazza in forum Items For SaleReplies: 9Last Post: 12-03-2015, 11:15 PM -
BUILD LOG: Monster fixed gantry router for aluminium & wood
By jonboycnc in forum DIY Router Build LogsReplies: 9Last Post: 12-01-2014, 11:26 PM -
BUILD LOG: Vertical fixed gantry. Design & build. (Steel/epoxy)
By Greeny in forum DIY Router Build LogsReplies: 8Last Post: 19-08-2013, 08:26 PM -
BUILD LOG: New build - fixed gantry mill using extruded profile
By toolchimp in forum DIY Router Build LogsReplies: 3Last Post: 09-11-2012, 04:10 PM -
BUILD LOG: Fixed Gantry Router
By lateAtNight in forum DIY Router Build LogsReplies: 24Last Post: 28-05-2009, 11:30 PM
