Thread: Engraving issues
Hey guys, I thought the machine was pretty good, setup wise, until I tried to do some small engraving (100x50mm) but turns out I have some issues!
Can anyone point me in the right direction with this as to what the issue could be?
All nuts and bolts are tight, no slop in any axis and slaved motors are spot on. I'm actually stumped
27-02-2016 #2
Cutter moved up in the collet???
27-02-2016 #3
Thanks Davek0975
Apologies I should of made more clear what my issue was. As you can see the curves in the engraving are horrendous! Straight lines are amazing.
The different thicknesses was me trying different depths
27-02-2016 #4
Ok, flat portions on curves are generally caused by slop in one or more axes, maybe a loose pulley or worn belt (if any)
27-02-2016 #5
An I've never checked the pulleys on the shaft! Will do that now
27-02-2016 #6
It could be the gcode too. Which programming you using?
https://emvioeng.com
27-02-2016 #7
I'm using Vcarve pro pal
27-02-2016 #8
Created DXF in solidworks THEN MOVED OVER TO V CARVE
27-02-2016 #9
Not used V-Carve so not sure of the options. Check to see if the arc are made up of straight segments or if they are real curves. It they are segments, then you there may be an option to smooth the curve. This replaces the straight lines with curves that make the program run better.
Failing that it may be mechanical.
Best of luckhttps://emvioeng.com
27-02-2016 #10
Cheers I will take a look. Mechanical wise everything's looking solid. Could it be a backlash problem? I had measured it but it was fine
50w laser - PSU issues?
By calida in forum Laser Machines & BuildingReplies: 1Last Post: 09-02-2016, 04:25 PM -
Limit switch issues?!?
By jonbabbz in forum General ElectronicsReplies: 10Last Post: 06-02-2014, 07:37 PM -
Calibration issues, advice needed
By Kernow Jim in forum Motor Drivers & ControllersReplies: 16Last Post: 23-01-2014, 07:18 PM -
Page layout issues...
By irving2008 in forum General DiscussionReplies: 3Last Post: 09-08-2012, 08:10 PM -
Cable + Connector issues
By tom3d in forum General ElectronicsReplies: 0Last Post: 09-01-2012, 07:56 PM
