Page 3 of 6 FirstFirst 12345 ... LastLast
  1. #21
    PUSSY.!!!
    Do you have an Earth lead on the machine.? If not then put one on and take back to Star Earth point. It was possibly static.
  2. #22
    Cheers, nothing like being blunt PMSL
    Nothing on the machine itself no. Star earth point?
  3. #23
    Quote Originally Posted by D-man View Post
    You should know this Dman you've been around long enough.!! . . . .Can't just throw this shit together and expect it to work perfectly.
    Star point is the Single Earth point in the Control box that you should have for all Gnd's and Shields to return to. If not then your open to Earth loop problems.
  5. #24
    phill05's Avatar
    Lives in Derbyshire  UK, United Kingdom. Last Activity: 19 Hours Ago Has been a member for 9-10 years. Has a total post count of 300. Received thanks 28 times, giving thanks to others 13 times.
    Before you go ripping into it have you checked ALL vectors are closed in V Carve before you toolpath. (closed not grouped) DXF are a swine to mess you about when imported into V carve.
    Phill
  6. #25
    Whatever you do, get a continuous earth from the body of the spindle (If metal) or the mount back to the star point as mentioned, without this, any stray voltage is going to earth via you ballscrews, nuts and bearings - this is seriously bad news and can ruin balls in short time, use multi-strand wire similar to heavy speaker cable etc - flexible but lots of strands.
  7. The Following User Says Thank You to Davek0974 For This Useful Post:
  8. #26
    Ok getting to the backlash, is this normal? Seems to bounce back then slowly zero, am I doing something wrong?
    This is on the left side of the gantry, bot on the right side it's a different story.
    http://youtu.be/GcV8a14q7xs
  9. #27
    Scrap that right side is now the same!
  10. #28
    Not sure it's made a difference. That "e" is wrote in VCarve. Could it be the processor settings?
  11. #29
    Changing the processor didn't help, well maybe a tiny bit, something is still not right and it's at the same pints all the time (at the black dots)
    Left is mach3 processor with ARCS
    right is mach3 processor with (MM)
  12. #30
    That is lost motion somewhere, either backlash or the screws/bearings are not tight. The blips happen when start accelerating when you change direction as you can see. Also have you changed any setting for backlash compensation in the software?
    https://emvioeng.com
  1. 50w laser - PSU issues?
    By calida in forum Laser Machines & Building
    Last Post: 09-02-2016, 04:25 PM
  2. Limit switch issues?!?
    By jonbabbz in forum General Electronics
    Last Post: 06-02-2014, 07:37 PM
  3. Calibration issues, advice needed
    By Kernow Jim in forum Motor Drivers & Controllers
    Last Post: 23-01-2014, 07:18 PM
  4. Page layout issues...
    Last Post: 09-08-2012, 08:10 PM
  5. Cable + Connector issues
    By tom3d in forum General Electronics
    Last Post: 09-01-2012, 07:56 PM
