    If your dial gauge has enough travel, you can also come back to the gauge position and overshoot a few millimetres, then return to zero from the opposite direction, so to speak. This will show up backlash in the whole system, rotating nuts included.
  2. The Following User Says Thank You to Neale For This Useful Post:
  3. #2
    Hi Derek,
    Dont rush to disassemble everything.
    That what you see on the dial indicator is the servo correcting after movement and fixing the gantry in position i believe.
    If needed mark with lines and marker and check in order both sides :
    -the 6 screws that tighten the ball nut to the rotating part
    -the big bearings on the rotating nut if they have not slipped on the housing
    -if 2 nuts that hold rotating part to nut are not loose
    Most possibly this is loose pulley, belt or end support problem. Check carefully all pulleys for slip, check if belts are well under tension/ same tension. Then check end supports if sth un screwed there. If not sure, disassemble motors and cement pulley again.
    In fact you should have cemented every single screw on the machine, which i discovered was my big mistake on the first machine i made.
    Ahh, and move gantry to one side Check with finger as you are pulling guitar strings if both screws sound with same pitch. If not, tighten all so that is the case. No need to check against tuner. But if you want to go so far, use Linostrobe on the phone. Other will not pick the sound.
    PS. And remove that backslash compensation in Mach3. this will additionally mess things up. I have a small machine with backslash and from experience i know its better without it.
    Agree 100% on BL-comp but look close Boyan and you'll notice it's not Mach3 Looks like Edding Cnc to me.? . . Still needs removing thou.
  1. 50w laser - PSU issues?
    By calida in forum Laser Machines & Building
    Last Post: 09-02-2016, 04:25 PM
  2. Limit switch issues?!?
    By jonbabbz in forum General Electronics
    Last Post: 06-02-2014, 07:37 PM
  3. Calibration issues, advice needed
    By Kernow Jim in forum Motor Drivers & Controllers
    Last Post: 23-01-2014, 07:18 PM
  4. Page layout issues...
    Last Post: 09-08-2012, 08:10 PM
  5. Cable + Connector issues
    By tom3d in forum General Electronics
    Last Post: 09-01-2012, 07:56 PM
