Thread: Engraving issues
I think I may have just found the problem.
Ball screw mound seem to move slightly
https://youtu.be/XFrAJuSvGoo
28-02-2016 #2
From the brief view in the video it appears that the screw end bracket has no triangulation!
- Nick
28-02-2016 #3
This is prime example when I say can't just throw these things together and expect to work perfectly.!!
No disrepect ment here Derek but that end fixing is pathetic and no way can you expect to hold fine tolerences done like that. The inertia of the gantry when cutting will rock those mounts like craddle.
The details are what make better machines and if poorly engineered or rushed into service missing these small details these are the results you can expect when get into finer work like engraving.!!! . . . . . The simple truth Derek is your machine isn't engineered good enough to do it.
50w laser - PSU issues?
By calida in forum Laser Machines & BuildingReplies: 1Last Post: 09-02-2016, 04:25 PM -
Limit switch issues?!?
By jonbabbz in forum General ElectronicsReplies: 10Last Post: 06-02-2014, 07:37 PM -
Calibration issues, advice needed
By Kernow Jim in forum Motor Drivers & ControllersReplies: 16Last Post: 23-01-2014, 07:18 PM -
Page layout issues...
By irving2008 in forum General DiscussionReplies: 3Last Post: 09-08-2012, 08:10 PM -
Cable + Connector issues
By tom3d in forum General ElectronicsReplies: 0Last Post: 09-01-2012, 07:56 PM
