Thread: Laptop stuck in BOotmgr missing
You normally need access to the bios to tell it to boot from the cd or usb, if its not responding to f2 or f8 then its foobar!
peterLast edited by ptjw7uk; 28-02-2016 at 11:16 AM.
28-02-2016 #2
What make and model? The keys to force different bios options vary with BIOS type.
Most laptops from the last 10 to 15 years come set to boot from in order of priority, if present - USB, CD, HDD
Remove the HDD and see what it does, you should at least be able to access BIOS without the system trying to boot from a potentially corrupt drive. HP Compaq have drive test utilities in the BIOS to check for hard errors.
Clean build of Windows? Dell will usually have a hidden recovery partition with the install media, others vary.
If your initial build had separate OS and data partitions you can rebuild Windows without data loss, if not you could put the drive in a cheap USB enclosure and use another PC to retrieve data (and test HDD integrity) before trying a build,
- NickLast edited by magicniner; 28-02-2016 at 12:18 PM.
Please help - missing steps ... Mach3
By emilvv in forum Artsoft Mach (3 & 4)Replies: 21Last Post: 23-12-2019, 08:31 AM -
feedrate stuck on low
By routercnc in forum Machine DiscussionReplies: 1Last Post: 24-04-2014, 10:24 PM -
So, what am I missing?
By Davek0974 in forum 3D Printing MachinesReplies: 4Last Post: 25-02-2014, 12:52 PM -
Boxford TCL 125 missing software
By Boxster in forum Boxford LathesReplies: 13Last Post: 03-07-2012, 06:21 PM -
250mW LASER stuck on
By korky in forum General ElectronicsReplies: 10Last Post: 12-07-2009, 10:47 PM
