Thread: Floating Head for 3020
28-02-2016 #1
I've got a 3020T 3-axis cnc primarily for pcb routing. Even with autolevelling, am getting some depth variation, so wondered if it's possible to get a floating head that would fit on this type of router?
I found this, which would seem perfect, but is obviously made for a specific machine, so will probably not fit:
http://www.prototools.co.uk/shop/customer/product.php?productid=18550&cat=523&page=1
Maybe this is impossible, but thought I'd ask.
28-02-2016 #2
The word Impossible doesn't exist on this Forum.
This is simple thing to make. Just linear rails with spring pushing down for tension. The depth is controlled with the adjustable height plastic depth control.
Daft as it sounds you could just remove power from your Z axis stepper so there is no holding torque. Fit strong spring to pull down on Z axis then fit plastic collar to the tool to control depth.!! . . . .Instant depth control.
28-02-2016 #3Ok try digging out a hole to move it else wareThe word Impossible doesn't exist on this Forum.
28-02-2016 #4
29-02-2016 #5
29-02-2016 #6
Hi
We have come across this before regarding PCB work, there was a post with a link to software to compensate, you secure your work and using a probe take readings to the face of the PCB or whatever in various positions(grid) the software uses this to plot Z axis offsets.
Regards
Mike
29-02-2016 #7
I want to adapt 4x4 CNC for plasma. Do I need a floating head or THC?
By marbles in forum Plasma Table MachinesReplies: 3Last Post: 28-11-2015, 08:07 PM -
Plasma floating head...
By Davek0974 in forum Plasma Table MachinesReplies: 27Last Post: 01-01-2015, 01:52 PM -
ballnut housing and floating end ballscrew assembly
By dsc in forum Lead Screws, Nuts & SupportsReplies: 12Last Post: 12-07-2013, 08:22 AM -
non-locating / floating bearing - shaft location
By dsc in forum Linear & Rotary MotionReplies: 5Last Post: 28-06-2013, 10:07 PM -
Driving floating end (ballscrew)
By blackburn mark in forum Lead Screws, Nuts & SupportsReplies: 16Last Post: 11-09-2010, 11:55 AM
