    I've got a 3020T 3-axis cnc primarily for pcb routing. Even with autolevelling, am getting some depth variation, so wondered if it's possible to get a floating head that would fit on this type of router?
    I found this, which would seem perfect, but is obviously made for a specific machine, so will probably not fit:
    http://www.prototools.co.uk/shop/customer/product.php?productid=18550&cat=523&page=1
    Maybe this is impossible, but thought I'd ask.
    Quote Originally Posted by iBeta View Post
    The word Impossible doesn't exist on this Forum.
    This is simple thing to make. Just linear rails with spring pushing down for tension. The depth is controlled with the adjustable height plastic depth control.
    Daft as it sounds you could just remove power from your Z axis stepper so there is no holding torque. Fit strong spring to pull down on Z axis then fit plastic collar to the tool to control depth.!! . . . .Instant depth control.
    Lives in Marple Stockport, United Kingdom. Last Activity: 15 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Ok try digging out a hole to move it else ware
    Easy.!! . . . First you Dig another hole and then Vacuum the air out of first hole and blow back into new hole. . .
    Thanks, yes, homemade may be the only way since I've a 57mm spindle - and there doesn't seem to be any floating heads for that diameter spindle. Not sure if just removing the power from the Z motor would be enough, the spindle is still attached to the thread.
    mekanik's Avatar
    Lives in Barrow in Furness, United Kingdom. Last Activity: 14 Hours Ago Has a total post count of 807. Received thanks 101 times, giving thanks to others 176 times.
    Hi
    We have come across this before regarding PCB work, there was a post with a link to software to compensate, you secure your work and using a probe take readings to the face of the PCB or whatever in various positions(grid) the software uses this to plot Z axis offsets.
    Regards
    Mike
    That's why you need a strong spring to pull down the Z axis. If strong spring can't pull it down then your Z axis is binding and needs looking at.!!
  1. Replies: 3
    Last Post: 28-11-2015, 08:07 PM
  2. Plasma floating head...
    Last Post: 01-01-2015, 01:52 PM
  3. ballnut housing and floating end ballscrew assembly
    By dsc in forum Lead Screws, Nuts & Supports
    Last Post: 12-07-2013, 08:22 AM
  4. non-locating / floating bearing - shaft location
    By dsc in forum Linear & Rotary Motion
    Last Post: 28-06-2013, 10:07 PM
  5. Driving floating end (ballscrew)
    By blackburn mark in forum Lead Screws, Nuts & Supports
    Last Post: 11-09-2010, 11:55 AM
