  1. The 2mt is to align the centre of the chuck to the centre of the rotab
    You'd normally do this with a dial gauge (mounted in the milling chuck) by tapping the rotab-chuck until the job is centred.
    If you just want to quickly centre the chuck just drop a length of 1/2" or 16mm rod down the chuck until it centres in the taper then tighten the chuck (admittedly, turning a short 2MT onto the end of the bar would make a better job of it).
    I agree that I could use a clock to dial it all in. BUT I thought it should be simple(easy) to align it with a bar and then perversity kicked in so as I originally said 'nothing in life is simple'.
    One of my likes about diy engineering is the seemingly simple ideas people have thought up to overcome difficult machining problems and I am often amazed at what has been accomplished on the 31/2 Myford lathe usually without a mill etc.
    Peter
  1. A new life - irving reborn after near fatal accident
    Last Post: 25-01-2015, 02:50 PM
  2. Tool Life Expectations?
    By Washout in forum Tool & Tooling Technology
    Last Post: 06-01-2014, 01:49 PM
  3. The tough life that formed Yorkshiremen?
    By WandrinAndy in forum General Discussion
    Last Post: 26-05-2013, 10:01 AM
  4. RFQ: Simple job cutting simple shapes out of camera lens cap
    By RockandGrohl in forum Projects, Jobs & Requests
    Last Post: 20-04-2013, 01:23 AM
  5. RFQ: Very simple small part
    By Shinobiwan in forum Projects, Jobs & Requests
    Last Post: 11-01-2013, 01:02 AM
