    Chaz's Avatar
    Ye just normal portland cement and to be honest looking again I think this cheap monitor I'm using is probably some of the reason it looks funny.!!!
    Lol. Ye, the 52.5R stuff is whiter than the white we are typing on here ....
    Probably why it's called SNOW Crete then. . Lol
    Chaz's Avatar
    Id guess its related. Its used extensively for architectural concrete work.
  5. #4
    Chaz's Avatar
    Some progress. Have removed some of the wood to see. Nice clean finish, no air bubbles (as expected with the plastisizer). Struggling to get the wood out, even with a mold release agent, its too tight to come out.
    I need some advice on sizing some metal. I want to build a frame below the concrete to hold the mass and allow some castor wheels to be mounted. Estimated weight will be 2000kg when done. Can anyone suggest what size mild steel tube I can use?
  6. The Following User Says Thank You to Chaz For This Useful Post:
  7. #5
    You could always build the frame out of UHPC as well. Just a thought
    What happened to that rod in the first photo?
    Fenza
  8. #6
    Chaz's Avatar
    Quote Originally Posted by Fenza View Post
    Fenza
    I could but I think its easier to weld something up quickly.
    The rod was some material that went into a pipe I was trying to use for a hole in the mould. It moved and filled with concrete, so thought that Id cut it open and inspect (once it had dried).
  9. #7
    If it was me i would use 100x100x4 and make a pallet from it. For me this is the ideal profile big enough, easy to cut at home, strong enough, cheap enough, ... . however reinforcing plates where the wheels are.
