Thread: Thor, or should that be Zeus?
18-06-2016 #111
26-06-2016 #112
Some progress. Have removed some of the wood to see. Nice clean finish, no air bubbles (as expected with the plastisizer). Struggling to get the wood out, even with a mold release agent, its too tight to come out.
I need some advice on sizing some metal. I want to build a frame below the concrete to hold the mass and allow some castor wheels to be mounted. Estimated weight will be 2000kg when done. Can anyone suggest what size mild steel tube I can use?
The Following User Says Thank You to Chaz For This Useful Post:
26-06-2016 #113
You could always build the frame out of UHPC as well. Just a thought
What happened to that rod in the first photo?
Fenza
26-06-2016 #114
27-06-2016 #115
03-07-2016 #116
Just need to drill some holes into the bearing holder, quick test fit. Have bought some reference surfaces (surface plate for the table) and also a fairly large box (engineering type, flat within 5 thou) that Ill use to cast the DWH against. I was going to try something cheaper but its risky and this will be better.
08-08-2016 #117
Quick update, been slow as I have been ill.
Getting ready to place the putty for levelling.
08-08-2016 #118
Chaz
Would you mind telling me the mix that you used ie cement, stone, fines and the water content byr weight or volume..Clive
08-08-2016 #119
08-08-2016 #120
There are currently 24 users browsing this thread. (0 members and 24 guests)
