Thread: Thor, or should that be Zeus?
28-05-2017 #221
A long shot, anyone near Uxbridge (I am willing to travel) that has a mill that I can use to get this Z Axis completed?
I need something that can do around 500 x 400 mm. I have access to a Bridgeport but no response from the person that offered. I just need to go around the rectangle and square up and do around 16 holes with some very basic code.
30-05-2017 #223
The Following User Says Thank You to Chaz For This Useful Post:
30-05-2017 #224
Managed to get access to a bridgeport type machine to do work on the Z Axis. Almost done, need to do a fair bit of tapping and will then assemble.
The Following 2 Users Say Thank You to Chaz For This Useful Post:
30-05-2017 #225
The Following User Says Thank You to Desertboy For This Useful Post:
30-05-2017 #226
30-05-2017 #227http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
30-05-2017 #228
I need to check, I bought two sets of components from my supplier, I think all in for 4 x 1180mm 45 Bosch rails plus carts plus around 6 different ballscrews (longer length) and 2 shorter length ones plus the a short set of rails and the Rosa ones being used on my Z Axis (700mm) was around €2500 or 3000. Not cheap but the 'list' price on a Bosch 45 Rexroth with rollerbearings and a set of carts is around €1K per set.
30-05-2017 #229
That seems reasonable I was thinking it would be even more! Amazing how being into cnc changes your perspective of reasonable lol.
So glad I only want to do aluminium and wood. This is definitely the most interesting (Read loony toons) cnc build I've ever seen if only for it's grandeur.http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
30-05-2017 #230
There are currently 58 users browsing this thread. (0 members and 58 guests)
