Thread: Thor, or should that be Zeus?
30-05-2017 #231
Ok, cleaned up a bit, removed the reference table, mounted the main table and did a quick test fit of the Z Axis bottom part.
The naked machine
Some bits on it
Z axis, ballscrew is just 'hanging' onto the overhang, not mounted. The Z axis needs some of the holes to be drilled all the way through and I need to find the location of the bottom carts. I did not have the measurement at hand when I machined the holes on the larger mill. As these are not threaded, I have a bit of margin for error.
The Following User Says Thank You to Chaz For This Useful Post:
30-05-2017 #232
That's looking a bit of a beast Chaz!
The Following 2 Users Say Thank You to njhussey For This Useful Post:
31-05-2017 #233
The Following User Says Thank You to Lee Roberts For This Useful Post:
31-05-2017 #234http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
The Following User Says Thank You to Desertboy For This Useful Post:
01-06-2017 #235
Can anyone recommend me a nice simple watercooling solution for the 4KW Spindle.
I had considered something like:-
6mm fish tank tubing (size to be confirmed)
Small fish tank pump
Some form of container that allows the heat to leave the cooling cylinder.
Ive seen some elegant solutions that use a CPU type cooler for a closed loop system, I am all ears ...
Something like this (With fans stuck on it) would work well
http://www.ebay.co.uk/itm/Baxi-105HE...UAAOSwA3dYPbSU
Simply splice the radiator into the return.http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
01-06-2017 #237
Thanks. Certainly an option.
I like this too, not sure how adequate it would be on a 4KW Spindle.
https://www.youtube.com/watch?v=2OZCviK0msg
01-06-2017 #238
I would worry that's underpowered but I also read you don't need a lot as the spindle are pretty efficient and don't make much waste heat. I'm going to use a 2.2kw spindle for maybe up to 10 hours per day 5 days a week I'm hoping a 200l barrel will be enough on it's own but if need be I'll use one of those heat exchangers I linked to I can get them much cheaper than that link from scrap yard friend so if you ever want one just PM me and I'll sort it out.
I'm only going to use a maxijet pump (Aquarium style) but it'll be fine as long as the head height is enough (Which it is 2m's) but will need to reduce it for the spindle (13mm standard hose pipe on pump)
The heat exchangers are 25mm pipe compatible
These fans are pretty quiet and pump a lot of air also cheap!
http://www.ebay.co.uk/itm/4-5-6-Bath.../261741641853?
Just drill some holes in the fan casing and cable tie it to the radiator it's probably best the blow through the radiator but even if you suck I bet it would work great.
You can fit 2 5" on the heat exchangers but 1 6" would be fine on it's own.Last edited by Desertboy; 01-06-2017 at 03:19 PM.
01-06-2017 #239
It seems most get away with 20 litres or less. Your 200 will be a massive overkill.
01-06-2017 #240http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
