Page 31 of 50 FirstFirst ... 21293031323341 ... LastLast
  1. #301
    Ger21's Avatar
    Lives in Detroit, United States. Last Activity: 2 Weeks Ago Has been a member for 9-10 years. Has a total post count of 651. Received thanks 90 times, giving thanks to others 0 times. Referred 1 members to the community.
    More likely your Mach3 tool table.
    G43 does not use machine coordinates. But it does change Z zero to correspond to the length of tool #2 (H2) in your tool table.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
  2. #302
    Chaz's Avatar
    It uses the one height set in the operation, but seems to ignore that it's not machine values and basically tries to go past the machine 0 and of course hits the limit.
    I'll snoop around later and do some testing.
  3. #303
    Chaz's Avatar
    Thor's Z Axis is alive. Short vid of it running on my very wonky table at 5000mm/min - 25mm cycles via the PID tuner. No tuning has taken place yet, Ill do this once mounted and limit switches have been installed.
  4. The Following User Says Thank You to Chaz For This Useful Post:
  5. #304
    Vertical Video Syndrome !!!!!! :
    https://www.youtube.com/watch?v=Bt9zSfinwFA
  6. #305
    Chaz's Avatar
    Quote Originally Posted by AndrewMawson View Post
    Lol, sorry.
  7. #306
    No offence meant Chaz. I hadn't realised myself why some videos were like that until I happened to trip over that explanation
  8. The Following User Says Thank You to AndrewMawson For This Useful Post:
  9. #307
    Chaz's Avatar
    And non taken.
  10. #308
    . . . . I hadn't realised myself why some videos were like that until I happened to trip over that explanation
    Thanks for that Andrew, I hadn't realised this until I just read your post!
    I thought videos displayed in three vertical stripes like that were simply some new technological fad intended to irritate some of us old farts! Lol
    Maybe people shooting vertical videos are often unaware of this, I certainly would have been.
    Let's hope the manufacturers improve their default settings to mostly phase out this mode of recording.
  11. #309
    Chaz's Avatar
    I need to order cable for limit switches (3 core for Proxy) and then 4 core for the Spindle / Earth.
    Do I need either of these cables to be shielded? 3 Core cable is common, shielding adds a fair bit to the price. I dont mind paying if its absolutely needed however no point if its just a 'nice to have'.
    Any suggestions for cable for the 4KW type Chinese spindles?
    Personalty I would use 4 core cy cable 1.5mm for the spindle
There are currently 19 users browsing this thread. (0 members and 19 guests)
