Page 34 of 50 FirstFirst ... 24323334353644 ... LastLast
  1. #331
    Chaz's Avatar
    Lives in Ickenham, West London, United Kingdom. Last Activity: 1 Week Ago Has a total post count of 1,657. Received thanks 115 times, giving thanks to others 71 times.
    Ye, ive been unlucky. Ive got 2 machines with native RS 232 ports as well as a USB one and PCI Express one. I cant get any of the 4 to work.
    I need to do it again, but busy finishing Thor. If all goes to plan it might do some basic movement this weekend on all 3 axis.
  2. #332
    Lives in East Lothian, United Kingdom. Last Activity: 3 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    I've got a cheap USB adapter, and have never had any problems. I did have to destroy the case to get it to directly fit onto the drives though.
    Are you using the correct type of cable?
    You'll need to check if it should be a straight through cable, or crossover cable (I would guess it should be a crossover for serial comms). Probably best to test the one you've already got, and then order the opposite.
  3. #333
    Chaz's Avatar
    I had tried a cable and had cut / moved the wires manually. I should just order one of each and test again.
  4. #334
    Chaz do you have the cable diagram for it. RS232 receive & transmit are on pins 2 & 3 sometimes they have to be reversed. Ground (if I remember) is on pin 7 on a DB25 plug and pin 5 on a DB9 plug
  5. #335
    Chaz's Avatar
    So what I've done is order a new F / M straight cable. The Kinco drive manual shows as default 2-2 3-3 and 7-7 wiring. Will try that first. Struggling to find (on Amazon) and null modem M / F cable in case.
    Problem Ive had is that on my Panasonic drives that use Serial / proprietary, Ive also struggled to get it working.
  6. #336
    I have a stack of about half a dozen HP DC7600 small form factor PC's that will shortly be going to the tip - you are welcome to all or any if you wish FOC. They have RS232 ports and multiple USB's - all have had their hard disks removed for security reasons - they are ex-corporate machines.
    (the clear out continues !)
  7. #337
    Chaz's Avatar
    Quote Originally Posted by AndrewMawson View Post
    Please. I wouldnt find 2 for using as basic PCs / Mach 3 / Serial device machines. Ill make a plan to collect from you or similar.
  8. #338
    sweet jebus Chaz, don't do things by halves do you!
    great work, look forward to seeing this thing in action
  9. #339
    Chaz's Avatar
    Thanks, nothing like your workmanship however. Perhaps Thor can build some pretty parts.
  10. #340
    Quote Originally Posted by Gary View Post
    you just need to have an RS232 connection to use the servo software, without Rs232, you will need to get a USB to RS232 adaptor.
    I have never used the interface on the driver to do any tuning, because it is so much easier using the software.
    Tuning with no load is not right and may cause the controller tuning to fail, or make the axis very spongy, so make sure you have the mass of the table there while tuning.
    Also make sure you save it after, or you will delete the tuning, once you cycle the power.
    Hi Gary, would a USB to RS232 interface not suffer the same issues as standard USB when it comes to timing's? Or is there something I am missing here.
    I also wonder if Linux is more reliable than windows (Especially when using USB) especially a Linuxcnc Live cd? I have no idea if you can get Mach 3 for Linux.
    Chaz I'll be interested to see if it was a crossed cable causing your issues, fingers crossed for your weekend movements ;)
