Thread: Thor, or should that be Zeus?
15-06-2017 #341
15-06-2017 #342Visit Us: www.automationshop.co.uk
The Following User Says Thank You to Gary For This Useful Post:
15-06-2017 #343http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
15-06-2017 #344
yes, he uses the csmio-ip-a that links to the PC with an ethernet cable.
17-06-2017 #345
Its alive !!!!
Still got to mount the spindle, wire some limits, tidy, PID tune, test. But getting there.
18-06-2017 #346
;)http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
18-06-2017 #347
So I tried to do the 'double up' with the limit switch for X. Make it home and limit. It goes home, but then when you try and drive the machine manually it says 'limit hit'. I know there is a manual override on the settings page, will try that.
18-06-2017 #348
Holly Jaws!!!
you are almostthere!
18-06-2017 #349
So, managed to make a small cut, nothing exciting. I need to sort the table. X and Y limit switches mounted and wired in. Having an issue with my Y motor holder, its not 100% level and causing issues, will sort.
Any thoughts on what I could use as a table? Ive seen alu T plates and similar for sale on ebay.
The Following User Says Thank You to Chaz For This Useful Post:
21-06-2017 #350
Argh, good progress, getting tuning right and then with the limits / home switches I was doing some test. I ended up somehow going past the X ++ endstop which has fortunately only cost me lost time as I now need to repack the ballnut and some of the cart bearings. Could have been a lot worse. Not sure why it ignored the limit switch.
I was setting the X and Y axis to be reversed as they are the wrong way around ( + and - direction ). Do people normally do it on Mach 3 or reverse either the -10 to 10V or swap motor leads (and encoder feedback)?
