Page 37 of 50 FirstFirst ... 27353637383947 ... LastLast
  1. #361
    Congratulations! Its so rewarding to see the result ++++++++++++
  2. The Following User Says Thank You to Boyan Silyavski For This Useful Post:
  3. #362
    Noice!
    You must be chuffed - looks like it'll be a monster.
  4. The Following User Says Thank You to Zeeflyboy For This Useful Post:
  5. #363
    Chaz's Avatar
    Lives in Ickenham, West London, United Kingdom. Last Activity: 1 Week Ago Has a total post count of 1,657. Received thanks 115 times, giving thanks to others 71 times.
    Quote Originally Posted by AndrewMawson View Post
    Excellent - congratulations !
    BTW do you still want those Compac PC's ?
    How big are they? Trying to work out if they will fit in my bikes top box, thanks
  6. #364
    If your top box is built like Thor then possibly !!
    They are 340 mm x 380 mm x 100 mm and I think that there are six of seven of them
  7. #365
    What cast of concrete ha ha ha, makes it slightly top heavy ;)
    Congrats on getting her cutting, lovely job Chaz.
  8. #366
    Chaz's Avatar
    I need some thoughts advice please.
    Material / structure to wrap around Thor to stop chips flying everywhere. Stainless plate, perspex, wood? Trying to keep it fairly cheap but still practical.
    Table, Ive got the upside down surface plate on it that I have mounted some ply on. I can keep using the surface plate, its high but not too bad. It only has 3 mounting points however. I could machine the top down a bit however not that keen to do that.
    Alternately I could remove the lot and install either tooling plate or something like this - http://www.ebay.co.uk/itm/Aluminium-...0AAOSwfcVUJXD5 - not cheap but looks good. The problem is mounting it, I need M12 capscrews (or bolts) for the carts and M18 for the ballnut holder. Both which will stop certain T slots from being available. The M18 bolts have a head thickness of 10mm, the plate is 20mm, so I should be able to machine a recess / hole setup for these but will loose the ability to use all the T Slots.
    Thoughts please?
  9. #367
    Poly-carbonate sheet is used in professional machines for chip control and operator safety. Used in Police riot shields. Don't use acrylic as it shatters. Even poly-carbonate will stress rack eventually if you make the fixings too tight - I need to replace the screens in my Beaver Partsmaster again having done it about four years ago - bolt holes should have had appreciable clearance for expansion and contraction, but I made them bang on :(
  10. The Following User Says Thank You to AndrewMawson For This Useful Post:
  11. #368
    Chaz's Avatar
    Thanks, suggested minimum thickness?
    Just saw a good vid where the guy was using small alu extrusion (looked like 20 x 20) for the frame, might try that.
  12. #369
    Chaz's Avatar
    Something like this might be good -
  13. #370
    I used 5 mm on both my Fanuc Tapecut Model L wire eroder and my Beaver Partsmaster CNC Mill
