Page 44 of 50 FirstFirst ... 344243444546 ... LastLast
  1. #431
    Lives in East Lothian, United Kingdom. Last Activity: 13 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,990. Received thanks 374 times, giving thanks to others 9 times.
    What probe did you buy?
    One thing you'll need to check, is what voltage/current the probe is designed to work with. I made up a small interface board for my probe, so it was only switching the designed 5V, so I could use it to switch a 24V opto. Details can be found in this post over on the mach forum - http://www.machsupport.com/forum/ind...html#msg195436
  2. #432
    Chaz's Avatar
    Two of these, almost a year ago, lol.
    https://www.machsupport.com/forum/in...ic,5004.0.html
  3. #433
    Chaz's Avatar
    So Ive bit the bullet and bought a 'proper' probe. Its mechanical, not electrical and I want to make an arm for it like the Datron has that comes down, probes and I can then move it back in the 'up' position when not needed. Thinking to use some form of offsets to make this work.
    How do I manage with an arm to rotate 180 degrees? Arduino Uno and servo? Id need a fairly strong servo me thinks ....
    Thoughts?
  4. #434
    Thoughts?
    Do you think it is possible to rotate about a hole/pin and get the repeatability ? How about sliding the arm up and down with a piece of spring steel to hold it against a ground edge? Could have a slot in the middle with a fixed dowel pin to give top and bottom end stops. Then add detents for top and bottom position. Manually move it up and down as required or drive it via a motor with a cam?
  5. #435
    Chaz's Avatar
    Well, I'm bad with this type of thinking. Datron have this on their machines (it pivots 180 down), so there must be a way but im not against it going up / down instead, anything I can look at on Youtube for inspiration?
  6. #436
    Chaz's Avatar
    So Thor has had a bit of an upgrade / make over.
    Spot the difference.
  7. The Following User Says Thank You to Chaz For This Useful Post:
  8. #437
    Go on Chaz give us a clue
    On another note what is the max spindle speed and a link to it would be nice.
  9. #438
    I know the answer but you told me lol having seen Thor though I could have spotted it anyway ;)
    Congrats ;)
  10. #439
    Chaz's Avatar
    Its an HSD ES909. 6.8KW 24K RPM with ISO 30 tool holding. Small issue to actually power it but working on that. It runs happily off 220V, even though its a 380V unit. I cant get to the wiring to Delta the motor (these came as options for both voltages) so I'm hoping that I can run off 220V for now. It has two thermisotors which will trip if it gets too hot. I dont need to cut at 6 KW, even at 2KW im removing a fair bit of material and I now have an tool changer. Buying balanced ISO 30 holders is pricy but will build up a collection once I am happy that this works reliably.
  11. The Following User Says Thank You to Chaz For This Useful Post:
  12. #440
    Chaz's Avatar
    A quick test cut. Looks like Ill be ordering more tool holders. Happy with the initial results. My Z is fairly heavy however (As predicted), might need to look at changing the gearing on both X and Z axis now.
  13. The Following User Says Thank You to Chaz For This Useful Post:
