Thread: Thor, or should that be Zeus?
18-06-2016 #2
Have you got any images of the final design you settled on Chaz?
50mm thick UHPC is pretty strong!
18-06-2016 #3
18-06-2016 #4
http://www.moertelshop.com/PCE-Flies...uenstig-kaufen
Polycarboxylate is the normal liquid superplasticizer. The shop I just linked seem to be pretty good and reasonably priced.
I'm going to try them out for some of my own experimentation.
Cheers,
Fenza
18-06-2016 #5
18-06-2016 #6
Chaz is the colour from the super plasticer or have you added pigments.? Also expected that you would have added fibres.?
18-06-2016 #7
Jazz, the cement is white. Snowcrete (basically). The stone is black and the sand then, well brown. The plastisizer is a light colour .... I suspect most of the colour is the mix of sand and cement.
I did not add fibres. It was discussed (with the guy providing me bits) and in his past experience it was pain to do and he did not feel worth it.
18-06-2016 #8
The ribs won't add any strength without rebar. the mix for small cross sectional beams/lintles ect is 3parts aggregate(10mm) 2 parts sharp sand 1 poart cement. but you still need the rebar.
i feel really bad about this as i should have mentioned it earlier.
But you seem to have gone into it in detail as you have with the rest of the build.
Mike
18-06-2016 #9
