Thread: Thor, or should that be Zeus?
23-08-2016 #2
Putty done, levels look good. I am using a surface plate upside down as a table but also to get alignment of the ballscrew / mounts before I putty the level for the bearing holder.
19-09-2016 #3
I am having some issues with the epoxy I ordered and its delaying my build.
Can anyone recommend an epoxy which is suitable to do hold things like nuts in place for where the rails get mounted etc?
Hi Chaz
This any good?
http://www.ebay.co.uk/itm/ANCHORSET-...8AAOSwq7JUGAUU
Mike
19-09-2016 #5
20-09-2016 #6
I believe this should work. Sika are well regarded as far as I understand.
http://www.uksealants.co.uk/sika-anchorfix-1--p84.html
20-09-2016 #7
Chaz I have used both of those in the past with great success. You will need to prepare all the hole first and blow any dust out. The nozzles on the tube are a duel flow type and in my experience cannot be used more than once so try and do the job at one sitting.
20-09-2016 #8
Did you use the Red or Green Anchorset Clive?
