Thread: Thor, or should that be Zeus?
25-01-2018 #40
the ecogoo is vector control- so gives great low down torque. - i drill 20mm diameter at 4000 rpm on my 24000 rpm spindle- never once stalled it.
also- for lathe you can use the 8 step preset speeds if required- so no need for variable control. and most induction motors are good for up to 75 hz with no problems- so you can up the frequency and get more speed at the same lower gearing.
with vfds running at lower rpm is where the current rises and creates more heat- then you have to force the motor with air cooling.
There are currently 15 users browsing this thread. (0 members and 15 guests)
