Wow, what a kind offfer, I'm starting from zip .....I'd like to take you up on that if the lathe turns out to take 10mm tools - thanks! (these will no doubt weigh a little bit...obviously I'll pay the postage!)
I'll let you know later!
You'll get a flavour for why I need a lathe from this set of photos, I've just completed this -
(those lines are on the lower surface - top is nice & smooth. That centre circle looks a little odd as I haven't come all the way through to the top surface with it . - also those little holes are meant to be different - there are two sizes of DIY pickups I need to mount, both of which have different pole spacings)
The cheapest/quickest traversing pickup winder I can dream up....
"What I learnt today" - biggish circular stuff is painful to do on a mill and doesn't look so neat after either!
(& I dare say not that 'true' either!)Last edited by HankMcSpank; 09-07-2009 at 03:00 PM.
09-07-2009 #2
Mach Turn
By Kai in forum CAD & CAM SoftwareReplies: 5Last Post: 02-08-2016, 02:40 PM -
11 hours of trying to get the motors to turn, help please
By Wotsit in forum Stepper & Servo MotorsReplies: 19Last Post: 05-02-2013, 03:07 AM -
LED not turn on
By Awel in forum Motor Drivers & ControllersReplies: 1Last Post: 06-12-2011, 06:59 AM -
Sieg Mini lathe - smallest diameter rod turn-able?
By HankMcSpank in forum Milling Machines, Builds & ConversionsReplies: 4Last Post: 18-11-2010, 01:15 PM -
Mini Lathes and their capability
By GeorgeD in forum Lathes, Lathe Rebuilding & ConversionsReplies: 8Last Post: 02-08-2010, 05:29 PM
