    Hank
    If all you want to do is turn small pieces i would consider second hand. Save yourself a fortune. i have a tiny unitmat that will only take up to 20mm in the chuck that does well enough. Decent cutters and cooling (bucket, small bore hose and a windscreen washer motor with sponge over the end) is priority. The lathe you see there is the same as clarke, axminster and sealey in the same clothing. I must admit i do have a bigger lathe but by the time you buy all the other tools to go with it-----phew fortune blown.
    Quote Originally Posted by 2e0poz View Post
    Hank
    The problem is that I need to turn up to 3"-4" lumps of acrylic...so I do need the larger chuck size.
    Have you a pic of that cooling system? I'm curious how the sponge fits into the equation (what's its purpose)
    Quote Originally Posted by HankMcSpank View Post
    Filter, goes over the pump pickup.
    Sounds overkill to me on a small lathe, ran one for years with nothing but a coffee can and a paint brush, at least you get it where you need it which isn't in your boots :heehee:
    John S -
  1. Mach Turn
    By Kai in forum CAD & CAM Software
    Last Post: 02-08-2016, 02:40 PM
  2. 11 hours of trying to get the motors to turn, help please
    By Wotsit in forum Stepper & Servo Motors
    Last Post: 05-02-2013, 03:07 AM
  3. LED not turn on
    By Awel in forum Motor Drivers & Controllers
    Last Post: 06-12-2011, 06:59 AM
  4. Sieg Mini lathe - smallest diameter rod turn-able?
    By HankMcSpank in forum Milling Machines, Builds & Conversions
    Last Post: 18-11-2010, 01:15 PM
  5. Mini Lathes and their capability
    By GeorgeD in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 02-08-2010, 05:29 PM
