09-07-2009 #2
What a splendid idea....do these soft jaws cost much? (cos it may be cheaper just to buy a 4 jaw independent chuck!
Perhaps I need to hold fire on this as there's stuff popping up that I'd never considered (& it's stuff that'll save me outlay!)
09-07-2009 #3
Soft jaws should only be about £20-£30 a set depending on the chuck manufacturer.
They do have more uses than just boring out the inside diameter to prevent runout, you can also bore out the face's with a shoulder for holding larger dia items. Say you had a 100mm dia circular bearing holder with a finish width of 20mm then you could bore the jaws at 100mm dia down to a depth of say 15mm, cut the 100 mm dia material a couple of mm's oversize in a saw and then when you put it in the chuck and tap it up to the shoulder it will run true and will be easy to get the width parallel.
Also if you bore them to the size of the part you are machining then it helps prevent marking of the workpiece that hard jaws can sometimes leave, specially on soft material like aluminum.
Mach Turn
By Kai in forum CAD & CAM SoftwareReplies: 5Last Post: 02-08-2016, 02:40 PM -
11 hours of trying to get the motors to turn, help please
By Wotsit in forum Stepper & Servo MotorsReplies: 19Last Post: 05-02-2013, 03:07 AM -
LED not turn on
By Awel in forum Motor Drivers & ControllersReplies: 1Last Post: 06-12-2011, 06:59 AM -
Sieg Mini lathe - smallest diameter rod turn-able?
By HankMcSpank in forum Milling Machines, Builds & ConversionsReplies: 4Last Post: 18-11-2010, 01:15 PM -
Mini Lathes and their capability
By GeorgeD in forum Lathes, Lathe Rebuilding & ConversionsReplies: 8Last Post: 02-08-2010, 05:29 PM
