Thread: Help needed with AutoCAD R14
I haven't used R14 since around 1999, but it should certainly save as R12 .dxf. Even current version still do.
Try using File >Save As, and click on the drop down list for file type. R12 should be the last one?Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
04-03-2016 #2
04-03-2016 #3
try typing DXFOUT in the command line.
Gerry
04-03-2016 #4
That works !
Again with Coreldraw I have an old version and do not intend to waste money upgrading. It does not translate to .dxf at all well. It seems that all lines have thickness and that causes twice the gcode and a lot of unneccesary cutter movement. Also curves are 'blocky' or 'steppy', however you like to describe it.
I have tried DraftSight, but that seems to be just a budget (free!) AutoCAD clone, nevertheless useful for what it is.
Cheers,
Rob
05-03-2016 #5
The trouble with AutoCAD comes when you create a mesh. At point of creation you have to define how many facets the mesh will have and you cannot go back and edit. You have to redraw if you want to change it. Each ENTITY can have completely different facet settings and they do not SCALE well. If you can stick to lines, arcs and circles then everything is fine and dandy. You can project lines and arcs into 2.5D by changing their THICKNESS but for real 3D work you need Solid Works or the clone thereof. That will allow you to adjust the facet angle and size parameters on the fly when you export the finished shape. CorelDraw is not an engineering product and should not be treated as such, it is for making pretties. You should only use it when pretties and engineering collide, usually realising graphic art and making signage.
I do like a good rant on Saturday morning, sets me up for the weekend. I shall go and blast 50 clays out of the sky with an antique muzzle loader tomorrow morning, bliss.Last edited by Robin Hewitt; 05-03-2016 at 10:41 AM.
05-03-2016 #6
I doubt that you'll find many people modeling with old style meshes in AutoCAD in the last 10 years. Meshes definitely have their place, if you understand and know how to use them.
But for the last 10 years, AutoCAD has become a very powerful 3D modeler, with a lot of new modeling features.
Lofting, nurbs, mesh subdivision, smoothing, solids. I would say that you can do at least 90-95% of what Solidworks can do in AutoCAD, if you know what you're doing.
THe biggest problem with 3D modeling in AutoCAD is that you need a pretty powerful PC if you're doing complex models. Until last year, I've done all my modeling in AutoCAD. But now I'm switching to Fusion 360, which is far more capable for 3D work, has built in CAM, and is about 15% of the price of AutoCAD. (And free for most hobbyists).
But I still use AutoCAD for my 2D machining. AT least until I have time to learn more about Fusion's CAM.Gerry
05-03-2016 #7
Have I opened Pandoras Can of Worms ?
a little more help needed
By terry1956 in forum Motor Drivers & ControllersReplies: 1Last Post: 29-02-2016, 05:52 PM -
3d AutoCad CNC machine parts.
By jcb121 in forum Open Source Designs & PlansReplies: 1Last Post: 09-10-2014, 10:18 PM -
Major issue with snapping to circles -Autocad 2013
By craigrobbo in forum AutoCADReplies: 8Last Post: 01-02-2014, 09:33 AM -
Concentric reducer in autocad
By Web Goblin in forum Computer SoftwareReplies: 1Last Post: 24-09-2012, 03:58 PM -
AutoCad 2007
By D-man in forum CAD & CAM SoftwareReplies: 15Last Post: 05-08-2012, 05:51 PM
