    Ey up chaps, I'm stuck.
    I have got a very old version of AutoCAD loaded on my CNC computer, which has no unnecessary software (networking etc), so the easy way of explaining my problem is to start with a photo of the screen
    What I am making is a harmonica case. The inside cutout is two rectangles and two circles. I want to end up with a pocket which is the combine of the four shapes. I can do the drawing in Coreldraw, and weld up the shapes, but when I transfer it to the CAM program (EstlCam) it produces a very 'steppy' outline, which is no use. I have to export the drawing to a .dwg file with Corel and then open it in AutoCAD and export it as a .dxf file to go into Estlcam. Somewhere in this process it loses the continuity of the shape.
    How do I make the four shapes into one outline ?
    I must admit that I do not understand the AutoCAD terminology. The program was bought for my son when he was a student in the late 1990's and I am unwilling to spend money on a CAD program, when there are so many free ones about and I am unlikely to use them to any worthwhile extent.
    Cheers,
    Rob
    Sorted - after a lot of messing about !
    iirc you type in the word TRIM :D
    Hi, sorry I meant to PM you!
    I have got past the stage of creating the shapes I need. Now I find I can't make them into a dxf file to put into my CAM program. All I get is the outer rectangle. I attach a copy of the dwg file, if anyone can help. The inside shape was created as a REGION and then made an outline with the UNION command.
    Here's the dwg file hc2.dwg
    Rob are you trying to convert it to DXF if so here it is
    Rob.dxf
  7. The Following User Says Thank You to Clive S For This Useful Post:
  8. #7
    Thanks Clive, but I was hoping to find out why I could not do it, What the Fun was I doing that the export command did not pick up the inner bit?
    I need to know so that I can do other drawings through the same process.
    Cheers,
    Rob
  9. #8
    Rob was load it into Acad and saved as dxf in your version.
    I don't understand why it does not do that for you.
  10. #9
    Maybe because I have a very old version of AutoCAD (R14). It only gives me the .dwg or .dwt option on save as. DraftSight does not export the file either. I thought it might be because I had to create a REGION to combine the shape and this put it on another layer or something.
    I tried 'Save As' .dxf in DraftSight and that did not work properly as well.
    I reckon it is because I feel knacked at the moment and everthing is working to Sods Law. If I have a fresh go at it over the weekend, I might see what is happening.
    Cheers,
    Rob
  11. #10
    I tried importing Corel to AutoCAD and it was exceedingly messy, Instead of lines and arcs I got some bizarre Bezier shapes the AutoCAD could barely understand and I did not like at all.
  1. a little more help needed
    By terry1956 in forum Motor Drivers & Controllers
    Last Post: 29-02-2016, 05:52 PM
  2. 3d AutoCad CNC machine parts.
    By jcb121 in forum Open Source Designs & Plans
    Last Post: 09-10-2014, 10:18 PM
  3. Replies: 8
    Last Post: 01-02-2014, 09:33 AM
  4. Concentric reducer in autocad
    By Web Goblin in forum Computer Software
    Last Post: 24-09-2012, 03:58 PM
  5. AutoCad 2007
    By D-man in forum CAD & CAM Software
    Last Post: 05-08-2012, 05:51 PM
