Thread: Help needed with AutoCAD R14
I have got past the stage of creating the shapes I need. Now I find I can't make them into a dxf file to put into my CAM program. All I get is the outer rectangle. I attach a copy of the dwg file, if anyone can help. The inside shape was created as a REGION and then made an outline with the UNION command.
Here's the dwg file hc2.dwg
03-03-2016 #2
Rob are you trying to convert it to DXF if so here it is
Rob.dxf..Clive
03-03-2016 #3
Thanks Clive, but I was hoping to find out why I could not do it, What the Fun was I doing that the export command did not pick up the inner bit?
I need to know so that I can do other drawings through the same process.
Cheers,
Rob
03-03-2016 #4
Rob was load it into Acad and saved as dxf in your version.
I don't understand why it does not do that for you...Clive
03-03-2016 #5
Maybe because I have a very old version of AutoCAD (R14). It only gives me the .dwg or .dwt option on save as. DraftSight does not export the file either. I thought it might be because I had to create a REGION to combine the shape and this put it on another layer or something.
I tried 'Save As' .dxf in DraftSight and that did not work properly as well.
I reckon it is because I feel knacked at the moment and everthing is working to Sods Law. If I have a fresh go at it over the weekend, I might see what is happening.
Cheers,
RobLast edited by cropwell; 03-03-2016 at 08:54 PM.
04-03-2016 #6
I tried importing Corel to AutoCAD and it was exceedingly messy, Instead of lines and arcs I got some bizarre Bezier shapes the AutoCAD could barely understand and I did not like at all.
04-03-2016 #7Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
The Following User Says Thank You to Ger21 For This Useful Post:
04-03-2016 #8
Thanks Ger, I have sorted it now. I must admit to my ignorance in using AutoCAD. I need a good tutorial and the timeand brain energy to go through it.
I am using AutoCAD from the '90's R14, so saving as anything other than a .dwg is not an option, and V12 is not in the export options list.
BUT I did what you said (I suspected it was the REGION problem) and it worked after a couple of fumbling attempts.
Cheers,
Rob
04-03-2016 #9
I haven't used R14 since around 1999, but it should certainly save as R12 .dxf. Even current version still do.
Try using File >Save As, and click on the drop down list for file type. R12 should be the last one?Gerry
04-03-2016 #10
a little more help needed
By terry1956 in forum Motor Drivers & ControllersReplies: 1Last Post: 29-02-2016, 05:52 PM -
3d AutoCad CNC machine parts.
By jcb121 in forum Open Source Designs & PlansReplies: 1Last Post: 09-10-2014, 10:18 PM -
Major issue with snapping to circles -Autocad 2013
By craigrobbo in forum AutoCADReplies: 8Last Post: 01-02-2014, 09:33 AM -
Concentric reducer in autocad
By Web Goblin in forum Computer SoftwareReplies: 1Last Post: 24-09-2012, 03:58 PM -
AutoCad 2007
By D-man in forum CAD & CAM SoftwareReplies: 15Last Post: 05-08-2012, 05:51 PM
